Page 54 of 58 FirstFirst ... 4444546474849505152535455565758 LastLast
Results 531 to 540 of 575
Thread: Integrated voice control in RR...
  1. #531
    Jun 2006
    DuPont, WA
    Cool. Also note a couple posts I made about using the voice control with iGuidance and artist selection:
    ControlSend() solved my native iGuidance voice control woes
    speech idea
  2. #532
    Nov 2004
    Using the "hotkey" option, how would one code sending the "hotkey" (i.e. F10) to voice control each time say freefone.skin was switched to? I mean I know how to get it to execute everytime freefone.skin is switched to but what is the actual code for the sendkeys part, "SENDKEY{F10};[Windowname]" ?!?
  3. #533
    Jun 2006
    DuPont, WA
    Quote Originally Posted by juve021 View Post
    I never got the RR built-in SENDKEY command to work for this. I tried everything that seemed to make sense. I finally used AutoIt and it worked just fine. I made an AutoIt script called VC_F10.au3 and compiled it. The script is simply this:
    Code:
    WinActivate("RoadRunner")
    Send("{F10}")
    Then I execute it with a button, like so:
    B00,20,519,72,82,"RUN;<path>\VC_F10.exe",""
    So you could just add this RUN command in conjuction with your switch to the freefone.skin. BTW, nice idea having the switch to the phone screen automatically prompt for voice command.
  4. #534
    Nov 2004
    Thanks Jeffw!! BTW, I've used your posted autoit script to compile "play [artist]" commands for voice control (tweaked it a bit for my music library format) and it works awesome! Thanks for that as well!!
  5. #535
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Voice Control not working now...
    I use to have voice control working but after RR udpates, I get the following error message "Run time error 440...Automation error". I went back to reapply all files from the 4/06 to the root of RR, tried 5/2/06 and 5/25/06 but still the same error message.
    Anyone else have this issue?
    Or is yours still working fine?
    Gee
  6. #536
    Jan 2007
    DFW Area
    Anyone got this workin? It was working fine but after rr updates, its no longer working.
    Gee
  7. #537
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by navputer View Post
    I got that error before I installed a fresh copy of SAPI 5.1. Did you try that already?
  8. #538
    Jan 2007
    DFW Area
    No, I have not tried to reinstall the engine. I will try that.
    Gee
  9. #539
    Dec 2007
    oh~~~ Awsome..... I can talked to my computer now... This has to be D best plug in.... Now i have a question. It seems like when music is on, VC is going crazy.. try to interpret whatever is coming out of the music. How are you guys dealing with this issue?
  10. #540
    Dec 2007
    If i understand correctly, until vc hears the keyword, it should not be ready to accept any command, thus it should not go crazy while music is on if i didn't say the keyword.. Isn't that how it works? I don't know why it's going crazy when it should only pay attention to the keyword..... Help me please...
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 05:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 03:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 10:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 01:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
