Originally Posted by Mattkins99
Sound like that should work but how do you setup the ini so that its constanly listening for commands.
In other words you remove the "computer" from the .ini, and make a hotkey for the mic on/off IN the window of RR VC...
set usekeyword=false in the Voice.ini file.Originally Posted by Kalt
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
Hey Mattkins i tried that but its still listening for a keyword.
The "excuse you" reply is way too sensitive and wicked annoying. I am going to remove it ASAP. The program is kick-***. I love it. Nice work. I'm not really familar with exactly how it works, so I'm not sure if this is possible, but would it be to add spoken word support at least for common names or maybe for words too that would be spoken only when searching for a file/list. In other words I speak "Searchfiles" and it brings up the search OSK. Then, Instead of saying "Letter J, Letter A, Letter N, Letter E, Letter T.... I could say "FindArtist" "Janet" "Jackson". Is that plausible?
nice work, works pretty good. tried the standalone and I get 'runtime error 429 Activex component cant create object.
yea unless the mic is dialed in it seems to really pickup on these. It was supposed to be a example where you could throw in speak but mine is stripped as well. I did comment it out for submitting for future downloads.Originally Posted by J187
For common phrases you can add SendKey commands so for "Janet Jackson" you could put:
<P VALSTR="janet">Janet</P>
<P VALSTR="jackson">Jackson</P>
and keeping them as two words you could share the jackson and add a Michael. The only thing with sendkeys is if the OSK would need to be in focus.
I did add the hotkey as a function button, F12 is a reserved key for debugging apparently so it is F10 at the moment and will try to make it settable in the Voice.ini file.
Anyone working on IGuidance control with this, if so, can i see an example of how the "sendkey" was executed.
for example ot get my favs to come up i use:
and to zoom in i useCode:"SENDKEY;{ENTER}{ENTER}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{ENTER}||GETFOCUS"
Code:"SENDKEY;{up}||GETFOCUS"
Hey I got thinking If you have this is still active for you I think you are on an older downloadOriginally Posted by J187
