Page 9 of 58 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 575
Thread: Integrated voice control in RR...
  1. #81
    Nov 2005
    Quote Originally Posted by Rosebud6
    The error was after the second SENDKEY, it had 4 downs which goes to the coord instead of POI.
    Also i dont think the ||SENDKEY;%f{DOWN}{DOWN}{ENTER} is neccesary. It auto cancels route if you start a new one.Just flame me if I'm wrong...
    Well I must confess, this one I borrowed from Chuck. I was using his skin to checkout how the commands behaved in RR and saw the gas button and it sounded like a great idea. He does a great job taking buttons to the max, how is this for a button code:
    "ACTIVATE;iGuidance||SENDKEY;{ENTER}{RIGHT}{DOWN}{ENTER}{UP}{UP}{UP}{ UP}{RIGHT}{ENTER}{UP}{RIGHT}{ENTER}{DOWN}{DOWN}{DO WN}{DOWN}{DOWN}{DOWN}{LEFT}{ENTER}||GETFOCUS||SWIT CHBUTTON;1>>ACTIVATE;iGuidance||SENDKEY;{3}||SWITCHBUTTON;1>>ACTIVATE;iGuidance||SENDKEY;{ENTER}{RIGHT}{DOWN}{ENTER}{UP}{UP}{UP}{ UP}{UP}{RIGHT}{ENTER}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN }{DOWN}{LEFT}{ENTER}||GETFOCUS||SWITCHBUTTON;1>>AC TIVATE;iGuidance||SENDKEY;{3}||SWITCHBUTTON;1"
    Go Chuck!
  2. #82
    Jan 2004
    Champaign, IL
    I had been having standby problems and whodwho was kind enough to look into it and come up with a fix. I thought that had solved the problem but it seems I am still intermittently having trouble:
    When I standby and then resume, speech is not recognized. Mic is not muted and I don't believe volume is turned down, but the only way to get recognition to work again is to go Ctl Panel -> Speech -> Configure microphone and run the wizard. After "Windows adjust the volume of my microphone" (man, I've said that sentence hundreds of times now...) all is good and RR speech recognition is back in business, like a champ.
    So how can I run a command on resume to reinitialize/readjust/re-whatever my microphone so that SAPI will survive standby?? Seems to be a SAPI problem, not a problem with whodwho's code.
    Can't say it enough, btw, awesome addition to RR!!
    P.S. This papaya takes perfect.
  3. #83
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by rjoek
    Have you tried reinstalling the 5.1 entirely? Sounds like a program glitch possibly. Also, are you using one of the three microsoft voices, Mike, Mary or Sam? I seem to remember weird things occuring with other voices.
    P.S. Don't take my papaya!
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  4. #84
    Apr 2005
    Quote Originally Posted by whodwho
    Go Chuck!
    If thats the case, then I'd imagine he has the Modded IGuidance (patched with bigger buttons), and then it would use another {down} in the FIND GAS. BTW anyone remember the name of the patch or have a link to the post with the patch for BIG button IGuidance?
  5. #85
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Whodwho, are you going to provide a complete update with all the changes to your first post again?
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  6. #86
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    This sounds just what I have been looking for...
    Currently using NaviVoice, and need to change Boris or "B.O.R.I.S" to something more befitting a female voice without upsetting the missus. A perfect excuse.
    As to testing with Iguidance, I would be most happy to oblige. It seems that the menus are slightly different between versions of Iguidance, as Rosebud6 has noticed. For example in NaviVoice speaking "Favorites" takes you to "Recent" in Iguidance version 2.1.2UK which I use. There are other commands such as "Carpool" which I don't think are applicable to the european version either.
    Best of luck with this project.
  7. #87
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    what rr version did you re-compile... my transparent gps doesnt work since switching to your version
  8. #88
    Nov 2005
    Quote Originally Posted by Sonicxtacy02
    Buried in the babbling text of the first post...
    It is compiled from the 1-15-06 source.
  9. #89
    Sep 2005
    UK
    I have to say I have just downloaded this and had a play and it is a good effort for some technology that is still not 100%. It works alot better than any of other voice software I have used.
    However I have a challenge for you. Which may relate slightly to the dictation part of the app.
    Do you think it would be possible to either by dictation or by creating some sort of XML voice script creator (that you would run manually everytime you updated your archive). To add all playlists and mp3 filenames (and any other media you may want). So that when you are in say your playlist folder rather than having to select the filename by scrolling up and down. You could just read it out and roadrunner would select it?
    That is the dream.
    Keep up the good work.
  10. #90
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by Cruizer
    That is the dream.
    A problem that I foresee with this, is that currently there is no way to jump to a specific song in RR unless you used searchlist. In which case, the searchlist command would have to be execute with text in the OSK.
    Please help.
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 06:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 04:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 11:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 02:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
