Page 1 of 58 123456789101151 ... LastLast
Results 1 to 10 of 575
Thread: Integrated voice control in RR...
    Nov 2005
    I found voice control to be a nice complement to car computing, I found if very useful and fairly accurate for the most part but I was running into limitations with adding commands and keeping focus on the apps I was trying to control from ones that I have tried. So I created one so I could modify as needed and made it very flexible for other apps. I made it so it would load a different command sets for the different apps and sets focus on apps it does not have api access too. Nothing hardcoded but some system commands (open CD, time and date, etc.)
    Anyways I wrote it in VB6 to possibly integrate it with RR since that turned out to be the front end of choice for me - Thanks Guino. Well that day came and I integrated a simple version of it and since RR is capable of sending commands to other apps it works well in the simple form.
    It can easily be modified to add for any commands RR can send and there is a SendKey function to send alphanumeric for text input and edit commands so you can add other sendkey commands but striped everything else for now. I added two indicators one for !MIC_ENABLED one and one for !ONCOMMAND for visual aid in the skin. There is a hotkey to trigger command mode - currently it is F10
    kth
    Highlights:
    * Supports most Road Runner Commands
    * Support for Destinator
    * Support for FreeDrive
    * Support for MapPoint
    * Support for iGuidance
    * Support for PhoneControl.NET - thank you zorro!
    * Support for XM and Sirus
    * Configurable greeting and randomized replies
    * hotkey to use as the keyword - currently is F10
    Recent Additions:
    ~ added confirmation for dial, shutdown and hibernate/standby commands
    ~ Dictation - free speech recognition for quick notes and textboxes
    ~ added confirmation to dictation
    ~ activate rules (command sets) by current screen - i.e. enable navigation rule only in GPS screen
    ~ added dynamic voice dialing - currently by switching to dictation mode(need to automate the switch) and saying "dial 7025551212"
    ~ added static voice dialing ie "dial home", this also works with buttons as well ("PHOCO_DIAL;7025551212")
    ~ added read from file - currently only txt files "read files"
    ~ added read from clipboard - allows you to copy text and it will read it "read clipboard"
    ~ added standby/hibernation back in since pulling code out of the rr.exe - 05-02
    ~ added doevents loop to rid of the gui hesitations while speaking - done - 05-02
    Current Efforts: - in current test version
    ~ added progressbar for mic volume - done
    ~ added configuration to setup different voices for commands, alerts, and reading - done
    ~ added Outlook schedule - "today's appointments", "next appointment" - done
    ~ added Outlook read email - "check email", "read last email" - done
    ToDo List:
    ~ finish 'What commands can I say' type help support
    ~ Playlist by voice - working!!! need to make it so you don't need exact title
    Other software:
    Here is a link to the Speech Recognition Engine - you will need to install the SDK as they don't have just the engine install available alone
    http://www.microsoft.com/speech/download/sdk51/
    Here is a MS tool to backup and restore Speech Profiles. It maybe possible to transfer from home to car, but I don't know how sensitive it would be on using a different Mic or different acoustics of home versus car.
    http://www.microsoft.com/downloads/d...DisplayLang=en
    05-02:
    added doevents while speaking to avoid hesitations
    05-20:
    added voice configuration
    added read email for Outlook
    added read appointments from Outlook
    Voice Control is now in Road Runner starting with 5-1 release - Thank you for including it Guino
    You will need to add the files below to your RR directory and
    add a UseVoiceControl=True line to the RR.ini
    Attached Files Attached Files
    Tainted Love Cris's Avatar
    Romania
    I can't really answer your wuestion, but I've been looking for a voice command software for a while now...I'd love to give it a go.
    Apr 2005
    I'd give it a go.
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    The road is long but we are getting there.
    Apr 2005
    Queens, New York
    x2
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    x3
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    its an open source program. There shouldnt be any issues.
    Romania
    Wow, this works great!!! I like it a lot!
    Oh, the computer is really chatty too...
    Thanks a lot whodwho! Awesome!
    One thing though. Once you press hide, you can't bring it back up, and it gets a lot of false commands (like "bless you" or "excuse you" - nice add), so there should be a button (maybe integrated in RR, or a short cut key) to enable and siable it. I think mute/unmute the mic is the easiest around this.
    Ok, off to train SAPI more... This is fun!
    Romania
    And just noticed: the "mute" command, also mutes the mic, so there's no voice solution to unmute.
    Oh, and it works with 5.0 too. I've now upgraded to 5.1, and will try it out with this version.
    Nov 2005
    You can change the "chatty" when you get tired of it by changing the 'repeat' option in the voices.ini file
    You can play with the sensitivity adjustments in the speech properties in control panel to adjust pronunciation sensitivity and accuracy versus speed. I have mine at 3/4 each.
    You can delete those out of the keyword.xml and recompile, it was just to show you could add speak entries there. You will find what will help with false recognition is to not use short commands they are more susceptible.
    If you hide the window you can say "system show yourself" and the window should pop backup. There is a button command to add to your skin that will enable/disable called 'MIC' could add one for show/hide the window as well.
    Mute will mute the response but the microphone is still active and should allow you to say mute again to unmute, let me know if that is not the case.
    and don't forget to "thank you" to the computer once in awhile...
  1. Recommendations : Voice Control
    By wolfebaine in forum Input Devices
    Last Post: 01-03-2006, 06:05 PM
  2. SpeakEasy Voice Recognition - Release 0.9.2
    By ruairi in forum Software & Software Development
    Last Post: 11-22-2005, 04:29 PM
  3. Voice control
    By Cheekz185 in forum Centrafuse
    Last Post: 06-23-2005, 11:35 PM
  4. request: voice control for videos
    By ryguy in forum Centrafuse
    Last Post: 06-09-2005, 02:04 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
