View Poll Results: Should the radioSHARK support be native in RR?
Voters
73. You may not vote on this poll
  • Yes
    70 95.89%
  • No
    3 4.11%
Page 16 of 20 FirstFirst ... 67891011121314151617181920 LastLast
Results 151 to 160 of 193
Thread: radioSHARK Plugin for RoadRunner
  1. #151
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by spjuenger View Post
    Are you guys getting good reception from your radioShark? I don't seem to get anything around the STL area.
    You have to use external antenna.
  2. #152
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Sofar tested on beta machine and works great. Modifying Alpine skin for record feature.
    Can't seem to get the AM part working or the indicator (REC) for recording. Recording status works great.
    ````` _____||.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  3. #153
    Dec 2005
    Miami-Florida-USA
    Exclamation Your feedback is required.
    Is it no one using RadioSHARK or everybody is just too lazy to post a feedback? People it is very simple: Without your feedback it will be no official RoadRunner release that includes native RadioSHARK support!
    Please leave you feedback.
  4. #154
    Jul 2005
    Bronx, NY
    Quote Originally Posted by Evolution VIII View Post
    Sofar everything seems to work great. The only issue I have is trying to switch from AM-FM. I assign a button with the code: "Radioband" and it does not seem to switch to AM. The recording part works great but can't get the indicator to show "REC" next to the "Radiostatus". I modified the "ON" radio skin with the REC and assigned a indicator with the code: "radiorecord".
    Does the old commands work? are there any more new commands?
    I also removed all the old settings from the ExecTLB.ini. deleted the radioshark.ini, radioshark skin files , radiosharkplugin, changed the :"RADIOSHARK","AM FM Radio" to "Radio,""
    I love the fact that I can Add / Delete and Modify preset stations.
    ````` _____||.\__
  5. #155
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by xs10x View Post
    Did you mean from "RADIOSHARK","AM FM Radio" to "DADIO", "AM FM Radio" ?
    Please download the executable again, you may have downloaded before I switch the commands.
    You can also use standard RR "FMAM" indicator. For AM/FM abd MHz and KHz indications.
    The old commands works on the plugin only.
    Here are the new skin commands:
    BUTTONS
    "RADIORECORD" - Start/Stop radio recording
    "RADIOVOL+" - Adjust radioSHARK volume up
    "RADIOVOL-" - Adjust radioSHARK volume down
    "RADIOBAND" - Change AM/FM
    "RADIOMUTE" - mute radioSHARK
    INDICATORS
    "RADIOMUTE" - Indicates if radioSHARK is Muted
    "RADIORECORD" - Indicates if RadioSHARK is currently recording
    LABELS
    "RADIOVOLUME" -shows radioSHARK volume
    "RADIOSTATUS" -Shows RadioSHARK status/recording status
  6. #156
    Jul 2005
    Bronx, NY
    yes, "RADIOSHARK","AM FM Radio" to "RADIO", "AM FM Radio"
    Going to redownload the executable and test this afternoon.
    ````` _____||.\__
  7. #157
    Jul 2005
    Bronx, NY
    Ok , I redownloaded the rr.exe and now I have everything working as well as the radioshark volume and "Rec" indicator. The only issue I have left is switching from AM to FM. I have assigned a button for this, with the code "RadioBand" and nothing happens when I press it.
    ````` _____||.\__
  8. #158
    Dec 2005
    Miami-Florida-USA
    Sorry, I had the typo in the button code. Please download it again.
    However, you don’t even need to use this button as RadioSHARK will automatically switch to AM/FM base on frequency.
  9. #159
    Jul 2005
    Bronx, NY
    Done Downloading. Tested on test machine and seems to switch from FM to AM. Going to test in my ride soon...
    ````` _____||.\__
  10. #160
    Jul 2005
    Bronx, NY
    Here is a pic from my alpine radio skin.
    Everything works:
    Tune, record, Am-FM switching, Mute, Function - to edit modify or delete presets
    *AM / FM indicators still do not work
    ````` _____||.\__
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. radioShark am/fm usb adapter with timeshifting
    By kickerks80 in forum Car Audio
    Last Post: 10-04-2004, 05:08 PM
  3. Help with winXP/hibernate/LCD plugin
    By dave123456 in forum Software & Software Development
    Last Post: 10-17-2002, 09:17 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
