Yes
No
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
Sweetness !!!
Can you give me a hand how to use it as standalone?
Correct me if I am wrong, the radiosharkpatch allows me to run skinnable radioshark?
Here is what I did, I copied the radiosharkpatch in the radioshark directory and ran it once, set the ini file standalone to True.
Now Where do I put the skin, the plugin and the ini file if I don't have rr?
Swedish site for CarPC's
http://www.bilpc.info
Sorry for the inconvenience but this is a RoadRunner plugin after all.
If you don’t have a RoadRunner installed and want to run as stand alone you must do some additional steps:
Create empty directory, name it whatever you want. Let say you name it: “C:\ProgramFiles\RoadRunner\”
Drop radioShark.ini in “C:\Program Files\RoadRunner\” directory (e.g. “C:\ProgramFiles\RoadRunner\radioShark.ini”)
Create empty text file in “RoadRunner” directory and rename it to “rr.ini” (e.g. C:\Program Files\RoadRunner\rr.ini) Add one line to it:
skinpath=C:\Program Files\RoadRunner\skin\
Inside “RoadRunner” directory create “skin” directory (e.g. “C:\Program Files\RoadRunner\skin\”) and drop the skin files in there.
Inside “RoadRunner” directory create “RadioSharkPlugin” directory and drop the “radioSharkPlugin.exe” in there.
That’s it.
I think I've done eveything you said.
I get an error after I double click the radiosharkplugin.exe
it says, C:\RoadRunner\Skins\ does not contain a valid skin! Check your settings and try again.
BTW, I create the RoadRunner folder on the root directory instead of in the Program files.
any suggestions?
I got the latest RR download and my radioshark is patched but when I try to use it in RR nothing happens wondering if someone maybe able to point me in the direction to get it working. I have set the settings in rr.ini as told to do but get no sound.
The RadioSHARK is natively supported in official release of RoadRunner version 10-08-06
