thanks.. I'm gonna test it tomorrowOriginally Posted by Evolution VIII
Yes
No
Got mine in the post today.. going to stick it in a new box tomorrow and attach a car aerial. I will code a skin for MC2.0 soon as I get a free hour.. Just tried this plugin.. works great very impressed with it, just crossing my fingers that it works as good in the car (the radio not your plugin)
thanks again m8
CdR
feeling kinda stupid.. Installed radioshark today.
Everything works wel except.. no sound :s
I do get sound while recording with "C:\WINDOWS\system32\sndrec32.exe" using radioshark. But this way I can only record sound.
Must be some kind of setting but I just can't get it running. plugin seems to work well! any ideas please?
Did a quick skin to match MC2.0 today and installed it in the car, found the best results for the aerial was to solder the inside of the car aerial to the fm aerial point on the board and the neg to the point above it (opposite side to the am aerial)
I noticed that the plugin takes it skin from the rr.ini file, and not from the resume.ini file if its there, which might confuse some peeps. Will the source be available for the plugin ?
cheers
CdR
CDRskull - Any chance of getting the skin you did for the radioshark? I was trying to come up with something myself that looked good with MC2.0 when I stumbled on your post here...
- Dan
not played with it much.. about 5 mins, so might be missing a few functions.
HERE
CdR
Thanks CDRSkull! Looks a lot better than what I was working on...
- Dan
Thanks for suggestion. I will check for "resume.ini" in next release.Originally Posted by CdRsKuLL
I still can't get it to sound. The plugin shows the skin but no sound or channels.
Am I doing something wrong? I removed the "N N" gap also.
Does the path have to be c:\roadrunner for it to work? I have mine under c:\program files\roadrunner
I have in my ExecTBL.ini :
/, Set Below the Path to Radioshark plugin (if used)
"RADIOSHARK","PLUGIN;RRRadioSharkPlugin;C:\Pro gram Files\Road Runner\radioSharkPlugin\radioSharkPlugin.exe"
Can someone post a menu.skin of the tuner part
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
