View Poll Results: Should the radioSHARK support be native in RR?
Voters
73. You may not vote on this poll
  • Yes
    70 95.89%
  • No
    3 4.11%
Page 3 of 20 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 193
Thread: radioSHARK Plugin for RoadRunner
  1. #21
    Jul 2004
    NL, Druten
    Do you get sound before patching radioShark? It seems i'm missng some setting here.. driving me nuts! I can't get sound!!
  2. #22
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Looks like radioSharkPath is not correct.
    Make sure you can start radhioSHARK.exe by it self without the plug-in. The patched exe should work as stand-alone providing all radioSHARK functionality.
    Make sure the “radioSharkPath” entry in the radioShark.ini (the file you drop in your RoadRunner installation folder) is the actual path of your executable.
    # path of the radioShark executable
    radioSharkPath=C:\Program Files\Griffin Technology\radioSHARK\radioSHARK.exe
  3. #23
    Jul 2004
    NL, Druten
    Thanks.. got it running now!
    Radioshark has to be connected by audio cable also (I thought it would be usb only) which was not mentioned in the guide. annyhow.. It seems to work now! audio comes from line-in. Is there anyway to pause winamp and unmute line-in while starting and visa versa while closing? I read something about this in the FAQ but not quiet sure how to configure..
  4. #24
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by TheKingPlaza
    Mine is connected via usb only.. First I just got it working with the software on the cd that came with it, once I got sound and got a couple of radio channels I then set about installing this kewl plugin.
    btw.. I soldered the car aerial adapter.. with the + going to where the original fm aerial went, and the - to the point above it..
    ie..
    o - neg on aerial
    o - pos on aerial
    o - am
    o - am
    0 - spare
    think thats right.. I got the best signal by using these points, unsure if there correct or not but I'm happy
    Another thing I noticed is the failer of the plugin to pull the correct format from the ini files for labels.. ie format of time. I know this isnt anything to do with your coding, but this has stopped me release a picture viewer plugin.. maybe guino could take a look
    CdR
  5. #25
    Jan 2006
    ie..
    o - neg on aerial
    o - pos on aerial
    o - am
    o - am
    0 - spare
    Here's a picture of the board, I'm in the middle of doing the same thing...
    CDRSkull - How's the AM reception in the car with the standard radioshark antenna?
    - Dan
  6. #26
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    I have mine workingthrough USB also. But it does not work once i launch the plugin. What am I doing wrong? can someone post the exectbl and menu.skin part.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  7. #27
    Jul 2004
    NL, Druten
    ExecTBL.ini
    Code:
    "RADIOSHARK","PLUGIN;RRRadioSharkPlugin;C:\Program Files\Road Runner\radioSharkPlugin\radioSharkPlugin.exe"
    button..
    Code:
    B,540,0,130,80,"RADIOSHARK", "AM FM Radio"
  8. #28
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm posting this plugin in RR's sites, I was just wondering if you plan to make the sources available at some point in time (even if after you don't want to make any more changes to it).. I only ask in case later on, if/after you loose interest in working on it, that other people could make improvements/tweaks as they see fit. But it's very nice to see a plugin done from the "basic" plugin interface .. Plus, this seems to be one of the best options for USB radio right now.
    Ride Runner RR's Myspace
  9. #29
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by guino
    I will release the source code after I done developing. I still have few ideas left. It would be nice to integrate radioSHARK into RR.
  10. #30
    Feb 2004
    Manchester
    yeah I would love that :-)
    CdR
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. radioShark am/fm usb adapter with timeshifting
    By kickerks80 in forum Car Audio
    Last Post: 10-04-2004, 05:08 PM
  3. Help with winXP/hibernate/LCD plugin
    By dave123456 in forum Software & Software Development
    Last Post: 10-17-2002, 09:17 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
