View Poll Results: Should the radioSHARK support be native in RR?
Voters
73. You may not vote on this poll
  • Yes
    70 95.89%
  • No
    3 4.11%
Page 5 of 20 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 193
Thread: radioSHARK Plugin for RoadRunner
  1. #41
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The plugin should be able to run the "pause" command when starting up, then start the radio. Once it is started, it should remain running when you exit the radio screen (the plugin allows for that to happen until the plugin itself closes). At last the plugin should monitor the current screen of RR (using the comsend/sdk interface), and if the user goes into the audio_player.skin or audio_browser.skin, it should shut off the radio, execute the "resume" command and possibly unload from memory (if desired -- this can be performed at the quit command on exectbl.ini OR the plugin can simply monitor if RR is still running and if it closes, it could just terminate as well)
    Nothing needs to be changed in RR to make this work, in fact, the pause/resume is a simple line of code from the plugin. The monitoring of the current screen in RR is probably some 3-4 lines of code. I can definitely help out if need be..
    Ride Runner RR's Myspace
  2. #42
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    You should make the plugin kill any previous instances of radioShark.exe before it starts too.
  3. #43
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    I don't have a radioSHARK, but I was asked to include a skin for it in my Alpine skins, so I have a question.
    Is it possible to have the presets in a scrollable list like the radio thats already in Road Runner, as apposed to having a button for each preset? This would save a lot of space and allow for truely unlimited presets.
    It's the cake having/eating thing.
  4. #44
    Mar 2006
    It doesn't survive a hibernate for me. When I resume, there's no sound and I have to restart the plugin.
    I'd really like to get the source for this so I can incorporate my Phidgets code to raise and lower my antenna. Right now I have seperate executables executing from the skin, but I don't see an easy way to make my antenna come after a hibernate this way. (I may or may not want it up depending on whether or not I'm in the radioshark plugin at resume.)
  5. #45
    Jan 2006
    When I switch to the Radioshark using Roadrunner and the MC2.0 skin, I briefly get a blank screen, with a pink stripe down the center. Basically I see the desktop with the stripe. Anyone else seeing that?
    Evolution VIII - definitely continue on with your work on this, it's a nice app... Thanks for all of your effort!
    - Dan
  6. #46
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You probably have a problem with your wait.skin file.. the wait screen is displayed briefly while loading any plugins in RR.
  7. #47
    Jan 2006
    Thanks Guino, that is exactly what it was. The wait skin was calling for an image that wasn't there. Once I made the image, everything worked correctly.
    - Dan
  8. #48
    Low Bitrate tasteItheIvalue's Avatar
    Nov 2005
    Connecicut; United States
    anybody wire up an external antenna to the thing? and hows the reception/sound quality?
  9. #49
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Exclamation New version released.
    The new version is released.
  10. #50
    Mar 2006
    The RadioShark application is appearing on top of Road Runner since I upgraded. Any idea why that might happen?
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 12:32 PM
  2. radioShark am/fm usb adapter with timeshifting
    By kickerks80 in forum Car Audio
    Last Post: 10-04-2004, 04:08 PM
  3. Help with winXP/hibernate/LCD plugin
    By dave123456 in forum Software & Software Development
    Last Post: 10-17-2002, 08:17 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 05:10 PM
