Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 91 to 100 of 120
Thread: BMW IBus-Heads
  1. #91
    Jun 2005
    California
    Quote Originally Posted by DarthTater View Post
    avidan - that's a bummer about the mini, I'm actually an apple guy so it would have been cool if you were able to get it to work! I'm not sure why the link wouldn't work, but here's a direct one to the pc page - BMWPC
    My site is hosted on .Mac so it may have been down for maintenance or something, I'm pretty sure I haven't exceeded the bandwidth. My PC installation has changed quite a bit from what's there, actually, but I haven't had the time to update the site.
    -Joe
    Joe,
    Is there any way that IBUScomm could be migrated to the Mac, using RealBASIC or some other means?
  2. #92
    Aug 2004
    I found an app called PortTerm which basically does all the functions of iBusComm. The developer is very responsive, and i think its worth the $10.
    Mac Mini BMW -- Done! (but always in progress) -- TOTALLED -- Damn lady didn't "see" the redlight
  3. #93
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by avidan View Post
    Hi,
    what link did u download from, does it do more than ibuscomm?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  4. #94
    Aug 2004
    http://kulesh-software.com/Software/PortTerm/index.html
    Its not meant to be iBusComm, but a more generic serial data reader. It is nice because you can have the app run applescript when it reads certain iBus commands....thats basically how i used it.
  5. #95
    Feb 2007
    Hi,
    Very interesting thread!!
    I have build a CarpC with a switch box to convert the VGA to the OEM Navi screen in front. When I set the RTS bit on the iBus serial interface, I can switch from CarPC to the standard screen in front.
    How can I setup in the ibuscomm.ini to use one of knobs of the original OEM Navi to pull this RTS up or down? And so easy switching from the OEM Navi screen to the CarpC screen.
    It would be great I someody could tell me this!
    Regards,
    Jan-Peter
  6. #96
    Aug 2004
    first off, welcome to the forums.
    which VGA conversion box are you using? I had purchased one from a group in germany, but had a hard time getting my PC to output the correct frequency.
    the way that ibuscomm.ini works is that it reads the ibus commands coming out of your car and translates them to keystrokes. so i guess what you will need is a shortcut key that your computer listens for and sends the RTS when it hears it...
    not sure what the easiest way to implement this with ibuscomm is, since i moved to a mac install a year ago.
  7. #97
    Feb 2007
    I'm using this VGA concersion box;
    http://www.shop.ac-services.eu/produ...nfo/p137_.html
    Thisis actually a IBUS reader to RS232 (or USB), and VGA to NTSC convertor. With a remote control you can adjust the video screen for the best performance. Works great!
    At the moment I use this with CarX as front end. However the software is not supported anymore.
    In the ini file I see an option what pulls the RTS line high/low. This is written in the ini file;
    ; Switched Line
    ; The switched line can be used to activate a relay to switch on for example, the
    ; video line to the PC and the Navigation computer.
    ; 0 : No switched line used
    ; 1 : RTS line used
    ; 2 : DTR line used
    ; A ProcessEvent=Enable will set the line to HIGH.
    ; A ProcessEvent=Disable will set the line to LOW.
    ; Status is LOW by default.
    SwitchedLine=1
    But I do NOT understand how I can select a certain keystroke to let Ibuscomm switch the RTS line.
    Probably the problem is I'm a Harware guy . But if somebody could explain me somthing how Ibuscomm works and what I have to change in the ini, I will manage to get it working. It can't be soo difficult...
  8. #98
    Nov 2006
    Wales, UK
    This is what im looking for by the look of it,this version 1.89 (of many adapted ibuscomm) released by Darth/Sama has the keyboard map & road runner commands, while all the others only have road runner support from the skincommands.
    I cant see anywhere in the ini config file support for the R/T and phone steering wheel buttons that the e46's have...
    Would this be a simple case of just pasting over the code from the other versions that have the capability this is the code from another ini file ive seen?
    Code:
    ;Steering Wheel PHONE Press
    [ID:STW_PHONE_PRES]
    MsgTemplate="5004C83B8027"
    KeyboardMap="MUTE"
    ;Steering Wheel - Press
    [ID:STW_RT_PRES]
    MsgTemplate="5003C8019A"
    KeyboardMap="PLAY"
    CarPuter Progress:
  9. #99
    Feb 2008
    how can i send a packet to the ibus? i am trying to control the IKE (display some numbers in the OBC on the cluster) i can see the stream of ibus packets using ibus analyzer .. i cant seem to find a version of ibuscomm that will let me SEND packets, just read them
  10. #100
    Nov 2006
    Wales, UK
    Quote Originally Posted by jonessc View Post
    Code:
    [ID:STW_PHONE_PRES]
    KeyboardMap="MUTE"
    [ID:STW_RT_PRES]
    KeyboardMap="PLAY"
    Problem solved by merging bits from an ini that supports the buttons, now works awesome.
    Quote Originally Posted by krusha View Post
    Theres a version called IbusRR (search using the google option itl be there on 1st page of results) it can send commands like open windows, lock doors etc, you can just tweak the ini file with the ibus codes that you want to send...
    CarPuter Progress:
  1. BMW IBus control for Centrafuse?
    By Hark in forum Centrafuse
    Last Post: 02-17-2013, 12:32 PM
  2. BMW multiple IBUS connectors
    By mudilik in forum General Hardware Discussion
    Last Post: 03-27-2006, 01:22 AM
  3. BMW iBus interface not working anymore
    By aiml27 in forum RR Bug Tracker
    Last Post: 02-21-2006, 11:24 PM
  4. BMW iBus - Any Other Use Other Than Steering Wheel Controls?
    By jmciver in forum General MP3Car Discussion
    Last Post: 02-12-2006, 10:26 PM
  5. BMW iBus Users needed!
    By Stevo759 in forum Newbie
    Last Post: 02-07-2006, 12:42 AM
