Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 120
Thread: BMW IBus-Heads
  1. #31
    Jan 2004
    Could you tell me how can I capture the log file? Thanks
  2. #32
    FLAC sama's Avatar
    Feb 2006
    London, UK
    select everything ni the window, that's the log
  3. #33
    Jan 2004
    OK. I will post both files tomorrow.
    One more thing, where it is supposed to disply the mid messages in an e46? In the radio display?
  4. #34
    FLAC sama's Avatar
    Feb 2006
    London, UK
    if you set the flag in the ini file to be FF, then it will send to all devices capable of displaying
    you should get it displayed in behind the wheel near the instrument cluster and the radio display
  5. #35
    FLAC sama's Avatar
    Feb 2006
    London, UK
    here it is chaps, scrolling text as promised! I have not tested it in the car yet, but it works on my screen here. let me know how it goes, it's the middle of the night and I'm not going outside
    Whenever a scroll is required, an extra 2 spaces will be placed at the end of the string, so spaces in the name can be distinguished from the end of the scroll (this of course assumed your song names don't have more than one consecutive space between them!)
    The ini file now contains the follwing extra fields to play around with.
    ; Tells the scrolling mechanism whehter to wrap the scrolled string or not
    WrapScroll=True
    so either this (true):
    Code:
    [T H E . T I T L] E . .
    [H E . T I T L E] . . T
    [E . T I T L E .] . T H
    [. T I T L E . .] T H E
    or this (false):
    Code:
    [H E . T I T L E] . . .
    [E . T I T L E .] . . .
    [. T I T L E . .] . . .
    ; The message length which to scroll beyond
    MessageLength=8
    ; The scroll speed in milliseconds
    ScrollSpeed=400
    the startup message will also scroll, as will any entries to the form directly
    I may add some more scroll styles. like this (bounce):
    Code:
    [T H E . T I T L] E S .
    [H E . T I T L E] S . .
    [E . T I T L E S] . . .
    and you would also control the number of bounces before it goes out. what do you guys think?
    enjoy, and let me know how it goes
    Attached Files Attached Files
  6. #36
    Low Bitrate DarthTater's Avatar
    Feb 2006
    Join me and together we shall rule the galaxy as father and spud.
    That kicks ***, Sama. I should have a chance to test it tomorrow! I'll let you know how it goes.
    See my install here:
    540i / 320i Mods
    Get a free and lightweight blog here
    iPhone Hacks
    Thought Soup
  7. #37
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I can confirm this works. I just tested it with FF as a target and both my MID and OBC cluster showed the message. The MID only shows 11 charachters while the OBC shows 19 or 20 (I just counted it but can't remmeber!)
    The scroll speed setting also works as does the wrap true/false
    however! there's a bug that you can't scroll more than 27 charachters! The reason being (I think) that the ibus packet is limited in size to 32 charachters
    68 XX 80 DATA CC
    That's 1 + 1 + 1 + 27 + 1 = 31 bytes - which kinda makes sense. So I'll be limiting the strings being sent to 27chars soon and see if that fixes it.
    I still can't get rid of this frigging foreground forcing loop thing. it's really ****ing me off now! I've turned off the flags etc. It doesn't happen in the original so I think I'll diff the versions, and start to slowly add the changes to see what's causing it. hell I'm gonna install VB on my carputer till I find out what's doing it
  8. #38
    FLAC sama's Avatar
    Feb 2006
    London, UK
    sorry guys, I'm talking to my self here. But here's an updated version that works with any length message, and here's an mp4 video to prove it
  9. #39
    Feb 2006
    Great job, sama. I just tested it and works almost perfectly. The only problem I came across was if you have a track name that is currently being scrolled and then change to a track that is shorter than the minimum scroll length, it will quickly flash the short track, but then continue scrolling the previous track. Something simple to exit the sub on the track change should fix it. Excellent work, though!
    540i / 320i Mods
    iPhone Hacks
    Thought Soup
  10. #40
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Thanks darth. here's a fixed version.
    I'll work on bouncing the string next.
    I've just had another thought. since we can have 20 charachters, how about this:
    Code:
    |<------ scrolling track name --------->|     2  1  :  2  3
    01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20
    That can be the track remaining time. this would hog the display, but if the code listens for any displayable messages and stops displaying for say 10 seconds when it sees one, then resumes, that should allow the other message to be seen on the display. We may have to resend the message in cases where the trackname was sent just before the other message was received.
    I was also thinking for users that have both the MID and high cluster, independant messages can be sent to both.
    what do you think?
    I've seen a post on hacktheibus that there's a message sent when reverse is selected. this is used to tell the passenger mirror to go down. I wanted to know if this is for both manuals and autos. I don't see why it shoudln't work for both but just wanted to check. what's ur transmittion? mine's an auto (sadly)
  1. BMW IBus control for Centrafuse?
    By Hark in forum Centrafuse
    Last Post: 02-17-2013, 12:32 PM
  2. BMW multiple IBUS connectors
    By mudilik in forum General Hardware Discussion
    Last Post: 03-27-2006, 01:22 AM
  3. BMW iBus interface not working anymore
    By aiml27 in forum RR Bug Tracker
    Last Post: 02-21-2006, 11:24 PM
  4. BMW iBus - Any Other Use Other Than Steering Wheel Controls?
    By jmciver in forum General MP3Car Discussion
    Last Post: 02-12-2006, 10:26 PM
  5. BMW iBus Users needed!
    By Stevo759 in forum Newbie
    Last Post: 02-07-2006, 12:42 AM
