Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 120
Thread: BMW IBus-Heads
  1. #41
    Low Bitrate DarthTater's Avatar
    Feb 2006
    Join me and together we shall rule the galaxy as father and spud.
    Mine's a standard. That might be a good way to implement a reverse camera. I'll try to do some ibus event logging tonight. There's a couple other messages I need to sort out to get my screen switching perfect, anyway.
    I think the independent message thing would be cool - then you could set two different scroll lengths! The scroll timers would probably need to be a little offset so that the bus doesn't get too crowded, though.
    *** edit: see version 1.[1].89 a couple posts down - this one had a problem!!! sorry.
    Here's my addition to your 1[1].87 code.
    I've enabled a crude version of hardware contention management in the ClearToSend sub. If you've set ContentionManagement to modes 3, 4, or 5 in the .ini, then the ClearToSend sub will check to see if there is traffic on the bus before returning a true value. Test your interface to see which line(s) are available to monitor. DSR, CTS, or CD = high, then the bus is clear. If low, then there is traffic. Not quite a full hardware handshake, but better than just the software method.
    See my install here:
    540i / 320i Mods
    Get a free and lightweight blog here
    iPhone Hacks
    Thought Soup
  2. #42
    FLAC sama's Avatar
    Feb 2006
    London, UK
    interesting. which ibus adaptor do u use? I got the one from eedesignkits or similar.
  3. #43
    Feb 2006
    It probably won't work for you then. I originally bought mine from eedesignkits because it was the only USB solution at the time. Those clowns have taken the SEN/STA pin on the Melexis chip and grounded it. This forces the Tx line open and shuts off any bit comparison between the Tx line and the iBus - ie. no hardware collision detection and no method to monitor the bus activity. I've since switched to Rolf Resler's V5 USB version. It will allow you to monitor the DSR, CTS, or CD lines. I used a handy little program called COM Port Toolkit 3.6 to test both interfaces. Try it on the eekit and you'll see what I'm talking about - the status lines will all stay high no matter what kind of ibus activity is going on. They should take the 'hardware collision detection' bullet off their site, it's simply not true.
    540i / 320i Mods
    iPhone Hacks
    Thought Soup
  4. #44
    FLAC sama's Avatar
    Feb 2006
    London, UK
    oh dear... wish I knew that then!
    but I guess I'm doing alright for now. if it poses too big a problem, I'll sell this or eat it or something
  5. #45
    Feb 2006
    Sorry guys, that last version was a turd. I put it together and didn't test it in the car first. I screwed up how I was handling the select case for the contention management. Here's a corrected version, I've removed the other one.
    Attached Files Attached Files
    540i / 320i Mods
    iPhone Hacks
    Thought Soup
  6. #46
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Hey Darth. could you try to fire up some visualisation in winamp from roadrunner whilst this ibuscomm (ibc hereforth) is on?
    I've tried all the forceforground settings in the ini file, and have even removed all calls to the method "ForceForegroundWindow" in the ibc code, yet still focus is somehow being hogged when both rr and ibc are on. That is, if I minimise rr and try to use something like notepad, focus is lost after milliseconds. same for launching externall apps from rr, like vis and gps.
  7. #47
    Feb 2006
    sama, I did a couple of different tests. First off, I do experience the same behavior when running RR and IBC at the same time. I guess I normally close RR when I'm doing some editing rather than just minimizing it so that's why I've never noticed before I guess. Just to confirm the problem, I ran the SDK Example that included with RR's source distribution - it has the same problem as well. So I think you were right to start with, the COM module in the SDK appears to be at fault for forcing RR to the foreground. I don't think I know enough about VB to fix this one. Maybe guino will be generous enough to provide an answer / possible soultion.
    540i / 320i Mods
    iPhone Hacks
    Thought Soup
  8. #48
    Feb 2006
    NWI USA
    .rar? you tell me you guys all have winrar licenses? insert fart noise- now I have to d/l some generic app to unzip this gem!
  9. #49
    FLAC sama's Avatar
    Feb 2006
    London, UK
    winrar works forever with an annoying msg, try http://www.rarlab.com/ for a free command line version
  10. #50
    FLAC sama's Avatar
    Feb 2006
    London, UK
    here's a video of this working
    Darth, I'm going to rewrite this app at some point. probably in Java as it's where my strength lies. I'll be able to speak to RR/other apps through Jacob (Java COM bridge).
    I've got some new ideas. here are some of them:
    - Since when the car goes off ibus activity dies. A software shutdown controller can be configured. this can still fall back on a hard shutdown by the main controller, if any.
    - Support for steering wheel double clicks, pressing two buttons at once, and mode switching. The latter means that the up/down arrow can either control next/prev track, or up/down for selecting songs.
    - Multiple tasks per event. So that more apps can be made to respond with functions, especially when switching modes.
    any other ideas are welcome.
  1. BMW IBus control for Centrafuse?
    By Hark in forum Centrafuse
    Last Post: 02-17-2013, 12:32 PM
  2. BMW multiple IBUS connectors
    By mudilik in forum General Hardware Discussion
    Last Post: 03-27-2006, 01:22 AM
  3. BMW iBus interface not working anymore
    By aiml27 in forum RR Bug Tracker
    Last Post: 02-21-2006, 11:24 PM
  4. BMW iBus - Any Other Use Other Than Steering Wheel Controls?
    By jmciver in forum General MP3Car Discussion
    Last Post: 02-12-2006, 10:26 PM
  5. BMW iBus Users needed!
    By Stevo759 in forum Newbie
    Last Post: 02-07-2006, 12:42 AM
