Page 11 of 58 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #101
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by gonthorn
    The reason I only run igcontrol on the fullscreen is that I have found no way to position it differently depending on the screens.
    Basically, to have it fit where I want it to on the fullscreen, it is at the wrong spot on the normal gps screen.
    Thus without the ability to place the button at different spots on different screens, I opted to only place it on the fullscreen skin as it fits there very nicely.
    And the reason I made EXIT5 is that while I do have RR buttons on the FS skin, when a normal exit was done, it did not close igcontrol, so I made EXIT5 to both go back and close igcontrol.
    You can make an autoit script that modifies the numbers in the coords.ini file and run that before you run igcontrol, that way it will move the button to different places based on the screen.
    beer replenishment fund
    mp3car live search
  2. #102
    May 2005
    Vienna, VA
    1. I did that part tho it is confusing, it asks if the entire scale is in the box, but only the number (500ft) can fit inside that small of a box. The number is inside the box.
    Yeah, only the number matters. I'll take a look at this issue again.
    As for the Guidance screen switching issue. Try this fix.
    http://download.andgear.com/rr/skins...GMon/iGMon.exe
    BTW, to help troubleshoot the AutoZoom problem better, do you have some kind of Com port simulator like Franson GPS Gate? This is so that you don't have to run out to the car to do the testing.
    Also, try this real quick for Auto Zoom. In iGMon.ini, set AutoZoomMode = 1 and PrimaryIGSkinMode = 1 (since I see you're using the Night mode).
  3. #103
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    This apparently doesn't work with IGLAUNCH.
    The wizard bombs with an application exception after it asks if you are using the title bar. When i click no it crashes
    note: it does work with regular i guadance embeded
  4. #104
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by antimatter
    Noticed that too.
    Ok i did more testing and with the settings and exe you gave me it did zoom down to 100ft when i changed the simulator to 15mph from 60, but it didnt do anything from there. No matter if i went slower or faster it stayed at 100ft. Everything else but this is working just fine now when plain ole iguidance is loaded in (w/o iglaunch igskinner n all that)
    Btw my iguidance is in day mode in that screenshot, though i had to put the day/night setting in igmon at 1 else it wouldnt autozoom at all
    Live mp3Car Facebook Chat
  5. #105
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Mine does nothing with IGLauch. I can go through the wizzard but when I run it it does show up in the taskbar but thats it. would be nice to have it working with IGLaunch. I don't want to see any borders in the screen.
  6. #106
    Woodbridge, VA
    Blog Entries
    32
    i'm hoping that the version later thats works with skinbedder will also work with iglaunch
  7. #107
    May 2005
    Vienna, VA
    Why do you use iGLaunch? What's the benefits?
  8. #108
    May 2005
    Vienna, VA
    SkinBedder users, download Beta 1.1 in the first post.
    Download everything and run the Wizard again.
    For LSX Void users, when the Wizard asks you what app to run when switching GPS, use "GPS" instead of "EXTERNAL" as in
    Code:
    exec.exe GPS
  9. #109
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by b8bboi
    two pics .. first without iglaunch second with
  10. #110
    May 2005
    Vienna, VA
    Then use iGSkinner. It also removes the file menu bar and everything. It's a later version of IGLaunch. They were both written by leelo.
    BTW, in the screenshots, I wasn't using iGSkinner. It was the original version of iGuidance.
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
