Here's where you can download iGSkinner.
[Release] iGSkinner BETA 3.9.5
IGLaunch removes all borders and toolbars. You get an intgrated look.
Does Guidance screen switching work with regular iGuidance? I think iGLaunch was messing with it.Originally Posted by Sonicxtacy02
As for Auto Zoom, can you do this for me? Take a screen shot when iGuidance is running. Open it in Photoshop or something. Cut the part where the Zoom Level shows and save it as a GIF. Then post it back here. I'm suspecting they were using a different font back then that throws off my OCR code.
I'll code up a debugging version later so you can test.
Whats the point of running IGskinner when your using the Justintime button mod. All we want is to launch and click the warning button and strip down everything except the map view. IG skinner is a little overkill and last time i checked a bit buggyOriginally Posted by b8bboi
i got the beta 1.1 and autozoom is now working!
Screen switching i really cant test with the simulator. Im on my way home in 40 mins and will fool around with it there. In all honestly screen switching is of least importance to me though.. i'm only testing it for bugs for others. As long as that popup shows on every screen i can live without the switching.
And yes i agree that igskinner is overkill. It doesnt quite embed correctly, but i tested igmod with igskinner embedded and its working so i might HAVE to switch from iglaunch
Once the popup is skinnable this will be exactly what you intended it to be .. the all in one solution![]()
Live mp3Car Facebook Chat
screen switching IS working now with beta 1.1
I swear i'm not post-whoring lol
I use iGSkinner in my car all the time. Not buggy at all. It's the same thing as iGLaunch, ie. you use it to remove the Nag screen and strip everything but the Map view. That's the point.
Great! See, please use what I use and save me the headache.Originally Posted by Sonicxtacy02
O.K. All, Hopefully this isn't off topic. If it, I will remove it.
What skin are you guys using to send commands from the RR to IG.
I have heard mention of the LSX Void skin. Any others. I want something integrated. I am thinking about using JIT's Big Button Mod. Just want to use a skin that is as integrated as possible, has buttons that sends commands to the IG, and will make use of IGMon as well.
Michael
iGMon now should work with iGLaunch
I just tested out with iGLaunch and was able to get it working. Please try the following.
Download iGMon again (Beta 1.1)
Run the Wizard.
When it asks you to Start RR and switch to GPS blah blah blah, just do Cancel.
Open iGMon.ini and change
iGuidanceWindowName =iGLaunch
IGHeightOffset =0
You won't be able to use the latter part of the Wizard so just read iGMon.ini and edit things manually.
Should work now. All these different versions of iGuidance, iGSkinner, iGLaunch are driving me nuts.![]()
The next person asks that I get iGMon to work with iGMod, I'll go postal on your ***.![]()
