Page 17 of 58 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #161
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Quote Originally Posted by b8bboi
    [*]Pausing RR when iGuidance is giving directions. You can also lower Winamp volume instead.
    I haven't had a chance to test this app yet.. but it sounds like what I've been dreaming of.
    One request though, would it be possible to have the option with the above to lower the line in volume, then restore it to what it was? I use an external XM app that doesn't use the winamp line in plugin, so this wont work for it. Just an idea, if not, no big deal. Once my XM app plugin for RR is done, it should be able to handle this..
    Thanks,
    Chris
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  2. #162
    Constant Bitrate cMags's Avatar
    Jun 2005
    Marietta, GA
    Anyone on the East Coast who's driving to an airport area, please save the log (File -> Record Track) then post it back here. There's one more color value I need to get for DirectionBoxColor.
    I'll be going to Logan in Boston on Sunday morning, so I can record that track. How much of it do you need? Just enough that I'm recording before I get into the airport area shown on the map?
    Also, do you need iGMon running during the track? Or is plain-old iG good enough?
    And finally, can someone email a copy of the beta 1.1 install to cmagnell at gmail dot com? My work firewall blocks the download. Thanks!
    CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
  3. #163
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by pyros
    Thanks,
    Chris
    Also I've set mine up to lower the winamp volume and restore it after giving directions. So much better, in my opinion, than pausing and resume. It seemed a little too harsh to cutoff the music like that. So instead of PAUSE and RESUME in the ini file, I used "exec SETVOL;winamp;30 and SETVOL;winamp;100 respectively.
    ... canadians
    J/K
    Live mp3Car Facebook Chat
  4. #164
    Mar 2004
    Toronto, Canada
    Quote Originally Posted by Sonicxtacy02
    ... canadians
    J/K
    I don't understand... the XM app doesn't use winamp.. and I cant have it lower the master volume or else it will lower everything so i need just to lower the line in volume..
    ...americans
    j/k
    My XM FAQ
  5. #165
    Woodbridge, VA
    Blog Entries
    32
    ...americans
    j/k
    which line does xm use? just substitute winamp with whatever line it is.
  6. #166
    May 2005
    Vienna, VA
    Quote Originally Posted by cMags
    When you go into an airport area, the background becomes gray. I just need the gray background to go over the top left corner where the Next Turn box appears. And no, you don't need iGMon running. I only need the .gps log file so I can play it back and grab the color.
  7. #167
    Mar 2004
    Toronto, Canada
    see.. now that is clearer.. thanks yank
    My XM FAQ
  8. #168
    Jan 2004
    NYC
    Upcoming Features
    When I get this version stabilized and when I find the time and motivation, these features will probably be added (in the order of most likely to least).
    - Disabling pausing for "ding" sound
    - More skinning commands
    - Better error handling in IGmon (so it crashes less often)
    - Fixing the font issue in the OSK input box (this is for skinners)
    - Skinnable popup with skinnable Next Turn Arrow (ie. provide your own images)
    - Displaying the Next Turn Arrow as an image on any RR screen
    - Numerical OSK for entering house number (overkill?)
    - Brand-new skinnable iGMon Menu system. Don't you hate it when you go to iGuidance Menu, the map stops moving? The new iGmon menu system will support transparency so you can still see the map moving underneath.
    - More consistent Auto Zoom
    - Skinning and magnifying the rest of iGuidance windows such as Favorites, Recent, etc.
    - Built-in embedding and removing borders from iGuidance so you won't have to use iGLaunch or SkinBedder, etc.
    - Optional anti-aliasing for fast PCs
    These ALL sound GREAT, please post a donation link hopefully that will give u some motivation
    Also any chance of you releasing the PSDs for iGmon's default skin so we can start making our own skins for this great app
    and someone get this guy his own subforum [zip-lock you there????]
  9. #169
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Yea... Please continue development. Seriosly man this is a heaven send. Your first two betas blow every other release of similar apps out of the water. You definitly got skills. I would love to see all of those other options especially the ding removal, Working Autozoom, Skinnable popup box, and Turn signal for inside RR skins
    Amen on the donation link. Lets get some motivation for you
    You Rock!!!
  10. #170
    Constant Bitrate WarningSLO's Avatar
    Dec 2005
    San Diego, CA
    All I want is the ding fix and I'll be totally happy with this mod, I mean mon.
    It's already awesome though.
    My Worklog
    My Mustang
    2006 Tungsten Grey GT | Dark Charcoal Leather | 18" Fanblades | Spoiler Delete
    C&L Intake | Bullitt Mufflers | MGW Short-throw Shifter | MGW Interior Pieces
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
