Page 20 of 58 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #191
    Raw Wave tj!2k4's Avatar
    Oct 2004
    nice, nice, nice =)
  2. #192
    May 2005
    Vienna, VA
    justintime, your PM box is full.
    tj, check your PM. I had jusintime do the same test.
  3. #193
    May 2005
    Vienna, VA
    camsgs3, nicely done!
    With all these skins poping up, I might add a feature in iGMon so that it can sync skin with RR. Basically, when you switch skin in RR, iGMon also tries to switch to a matching skin.
  4. #194
    Jan 2005
    Phoenix, AZ
    Wow! This is sweet! I really dig the OSK, but I am having one issue: When attempting to look up a POI with multiple locations (For example, a grocery store chain would have multiple locations under the same name), the OSK/Zoom gets confused and won't go any further. It appears that iG keeps the focus on the built in iG keyboard, instead of the new selection box where you pick a location.
    Other than that, this is awesome!
    1998 BMW M3
    Mods: Staggered SSR Competition wheels : M Roadster Short Shifter : JTD Aluminum Underpanel : Koni Adjustable SAs : Eibach Pro-kit springs : European clear corners and side markers : Hardwired V1 automatic door and radar detector
  5. #195
    Variable Bitrate nameeri's Avatar
    Mar 2006
    SoCal
    Quote Originally Posted by camsgs3
    lookin good guys,
    Here is my WIP...what do u guys think
    Brushed Metal skin
    This OSK looks sick! Just what I was looking for. do you have the .skin file for this one yet?
    Civiputer: Dont have one anymore, but here is what is used to be!
  6. #196
    May 2005
    Vienna, VA
    Quote Originally Posted by fliplap
    Yup! Bug confirmed. Will be fixed in the next release.
  7. #197
    Jan 2004
    NYC
    Quote Originally Posted by nameeri
    na man not even close, i just messed with it for a little....ill doo some more tomorrow
    you guys think i should leave the OSK as is, or make the up,down,back, magnify glass brushed tooo...i think it breaks it up a little
  8. #198
    Jan 2004
    NYC
    someone please post there iglaunch setting i cant get this embedded in RR, it works outside RR...but once i open RR i seee the dam borders
    RR is set to external, windows name is iglaunch
    and my iGlaunch ini file is like this:
    [SETTINGS]
    FILENAME=C:\Program Files\iNav\iGuidance\iGuidance.exe
    DIRECTORY=C:\Program Files\iNav\iGuidance\
    PARAMETERS=
    TITLE=iGuidance
    COMMPORT=5
    RECONNECTGPS=TRUE
    DELAY=200
    DELAY_1=100
  9. #199
    Mar 2006
    SoCal
    Set your RR window name to : iGLaunch
    your iGLaunch ini file looks fine. Also, your iGMon ini file should have the window name set to iGLaunch
  10. #200
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Ok, this looks pretty great but I just can't get it going. I'd just like to run it and have the nag and menus removed, so what's the recommended method with the least amount of overhead: iglaunch, igskinner, or skinbedder?
    I tried the skinbedder method (only because it superceeded igskinner and iglaunch) so I set RRconfig to point to iGmon and pointed igmon.ini to skinbedder but I only get a grey screen now. Can someone detail how each app points to the next in the chain?
    I feel so dumb. A brand new app and already too much to read to get it to work!
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
