Originally Posted by
kbreeden
I've had it running for a while now and have a couple of issues/questions. I'm using 2.1.2NA with the blue 800x600 CFX skin:
1. The gray pop-up next turn indicator doesn't come up every time and when it does it doesn't contain any information about the next turn. It usually just says "Next Turn" and has the number 3.
2. I am unable to switch to full screen. It's no big deal, and I'm really just looking for confirmation that full screen isn't supposed to work.
3. I'm using the XPort3 com port splitter. Before installing IGMon both the RR speed limit indicator (port 8) and IG (port 9) were working. After the IGMon install the RR speed limit indicator no longer works. Auto-zoom in IGMon doesn't work for me either so I'm assuming that the install somehow messed up my RR port setting. Can someone tell me how to reset the RR port setting? My rr.ini shows my nav as port 9, which is correct, but is there a separate rr.ini setting that determines the port that RR will use?
