Page 3 of 58 FirstFirst 1234567891011121353 ... LastLast
Results 21 to 30 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #21
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by b8bboi
    Like I said, if CF doesn't hide IG when switching screen, you'll end up with a magnified area that'll always remain on the screen.
    Gotcha.
    Auto-zoom draws the current speed from RR to determine the zoom level. Earlier, I tried to draw the speed directly from IG but failed.
    BTW, you can disable all those RR-specific features through the INI if you like. You can always use the OSK, I guess.
    Does/can your app read the speed directly from NMEA strings? If so, would it be possible to use a port-splitter such as Xport3 to provide your app with the NMEA sentences, and thus enable auto-zoom outside of RR?
  2. #22
    Jan 2004
    NYC
    b8bboi,
    will this only work with your skin?
  3. #23
    May 2005
    Vienna, VA
    Purdoom, I do a customized OCR on the street name area. The buttons automatically snap onto the edges of IG so it'll work with any solution. The OSK is 800x480 but it can be scaled to 800x600 by change some INI option just like Road Runner.
  4. #24
    May 2005
    Vienna, VA
    Quote Originally Posted by tj!2k4
    Yes it can theoretically do that. I just need to find a DLL that can read from COM ports. MSCOMM32.ocx is kinda crappy. Plus you'll need a runtime license for that.
  5. #25
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Wow! Ill sit back and watch you do your thing.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  6. #26
    Oct 2004
    Thanks..
    Dave
  7. #27
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Subscribed and standing by for first download.
    This may make me switch back to iGuidance.
    Anxiously awaiting release (vigorously rubbing hands together and evil laugh)
    Cheers
    BJ
  8. #28
    May 2005
    Vienna, VA
    Quote Originally Posted by camsgs3
    b8bboi,
    It will work with any skin.
  9. #29
    Constant Bitrate cMags's Avatar
    Jun 2005
    Marietta, GA
    I've got 2.1.3NA as well, and will be very willing to test this out for you. That is, of course, if I can figure out how to get RR and everything running right, as I haven't yet loaded a frontend on my carPC. I just finally got to the point where my hardware is mostly set up enough to begin really customizing the software - up until this point I've just been using Winamp and iGuidance.
    *subscribed*
  10. #30
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    i havent finished with fabrication. but when im done i will be using Iguidance with roadrunner. I wouldnt mind trying this out also. looks awesome man.
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
