Page 30 of 58 FirstFirst ... 202122232425262728293031323334353637383940 ... LastLast
Results 291 to 300 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #291
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    @b8bboi: I been playing with IGmon and Fp and so far everything work as I wanted.
    one question:
    There is a part in the wizard (and also can be found in the .ini) where your app execute a program before and after is giving directions so, is this proprietary to RR? cus I'm putting together a little .exe to pause and unpause FP when giving directions and I want your app to execute it.
    Thanks.
    Thanatos.
    Edit:
    little pic:
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  2. #292
    May 2005
    Vienna, VA
    You can use any executable you want. (you might need to use absolute path).
    Same deal with the automatic gps screen switching but not sure if you can do that in FrodoPlayer.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  3. #293
    Nov 2004
    Can you elaborate a little more about "absolute path"?
    Thanatos.
    Nissan Aux-in MOD
  4. #294
    May 2005
    Vienna, VA
    Something like this
    Code:
    C:\Program Files\Your Folder\Your_App.exe
    instead of just exec.exe like in the INI.
  5. #295
    Nov 2004
    ohh got it!! when I tryed it before ask I put the path in the wrong place..
    Thanks for the clarification.
    Thanatos.
    Nissan Aux-in MOD
  6. #296
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    Any updates ?
    K301 7" Motorized Screen
    Mini SLIMPRO SP625 Cappucino PC
    RoadRunner / IGuidance 3.0
    Pioneer 7700MP HU
    MTX 1500D 1500 Watt Sub Amp
    2 x 12" MTX 8000 subs
    1998 Olds Aurora 4.0 V8
  7. #297
    Newbie AlfaPC's Avatar
    Jun 2005
    Portugal
    b8bboi,
    The OSK is not showing up in Iguidance 2.1.2 Europe.
    Can this be a problem with the original IG OSK window name/class/handler being different from the NA version?
    If so, i can find out what´s the name/class of the window and post it here, for you to fix it .......
    If you need someone to help you with development, especially if we´re going to have a "IGMON - European Version", count me in.....
    AlfaPC
  8. #298
    May 2005
    Vienna, VA
    Alfa, does everything else work for you?
    There might be a small problem with focus. When the address dialog comes up, you can try clicking on the box to set the focus on it. The OSK should show up then. Next release should fix this problem anyway.
    NRGZ28, I'm still testing iGMon in house and in my car. The next version is drastically different code-wise. I want to make sure it's relatively bug-free before releasing.
  9. #299
    Jun 2005
    Portugal
    b8bboi,
    I´ve only tried at home. The zoom boxes works well.
    I´ve already tried clicking on it but still doesn´t work.
    I use the Skinbedder from "LSX void".....
    I´m gonna double check the "focus problem" without using skinbedder.
    In the OSK.ini there´s this lines....
    ";This is the title of the original IG window, for eg., Enter Street Name, etc.
    ;x, y, width, height, [font name], [font size], [color (in HEX format such as FFFF00)], [Alignment (LEFT, RIGHT or CENTER) - Default is Left]
    HeaderText = 4, 13, 241, 43, "Arial Narrow", 20, FFFFFF, "CENTER"
    Can you explain what´s this for? I´ve changed the titles (Enter Street Name, etc...) from english to portuguese!!
    AlfaPC
  10. #300
    May 2005
    Vienna, VA
    You mean you use reshack to change the titles to portuguese? That's why it doesn't work. iGMon looks for the original English titles.
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
