@AlfaPC
I have the german version --> titles are german too
I think that's the problem...
Please can you send me a PM what you have changed with reshack. (I
have problems with resizing buttons)
Yes, i have used reshack to change a lot of stuff...![]()
So it looks like we are going to have IGMON - Portuguese Edition !!!
Seriously, i´m not going to ask you to release a version for each language but i´m thinking that your code could fail because of differences between the American and UK original titles.
Winni,
Did you change the titles to german or are you using the original english???
AlfaPC
@AlfaPC
No problem.Originally Posted by b8bboi
I'm waiting excitingly...
...and hope for the next releases
Winni
Hi b8bboi, can I throw a feature request into the hat?
When you pan a screen (hold down the mouse & move it so you can see something off the current screen), the only way to get back to the regualr view is to
a. Hit the "x" key on the keyboard or
b. click the "x" button on the bottom right of the screen.
Everytime I try to hit that X on the screen, it activates a button on the last screen I was on (usually XM, so I switch stations or something). Is there a way to move or make a macro for that button?
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Ok, so I have roadrunner installed with the CFX 800 600 skin setup. I have iGuidance 2.1.1NA installed.
I downloaded iGmon and extracted to a folder in My Documents, then ran iGMon Wizard and completed the steps when promted.
Now when I run GPS in RR, iGuidance loads with no changes. Am I doing something wrong? Do I have to copy some files to the iGuidance folder or RR folder to make it work?
Thanks!
after you run the igmon wizard you need to run the igmon exe. then restart roadrunner. You might want to place the igmon.exe in the startup folder.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
I am having problems with the next turn label.Originally Posted by b8bboi
this is the label code I added to get it to work but doesnt.
did I do something wrongOriginally Posted by Label Code
