Page 50 of 58 FirstFirst ... 40414243444546474849505152535455565758 LastLast
Results 491 to 500 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #491
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    ? SKINbedder (as well as iG launch I believe) can "crop" any window. You should easily be able to remove any type of boarder. Maybe iGLaunch doesn't work with iG V3, but you could definitely do it with SKINbedder (the newer "universal" version of iGLaunch).
    If someone wants to send me a copy of iG V3 I will be happy to do this for you LOL.
  2. #492
    Raw Wave justintime's Avatar
    Apr 2005
    Well, it is not removing any borders with iG3. I tried iGlaunch v3 and 3.5 I am trying to avoid the more bloated SkinBedder.... because I will not use button overlays etc...
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  3. #493
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Quote Originally Posted by RPM_VR4
    Yes I does.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  4. #494
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    iglaunch works with v3. I use it and it works great. Another question for ya b8bboi. I know you said there's no support for v3 yet, but only thing we need to change as far as i can see is the parsenextturn area. As you can see in my screenshot its in the correct Y position but the box is too small to capture the streetname in v3. Is this somethin we can correct in the .ini or is it somethin in the program that sets the size of that box?
    Live mp3Car Facebook Chat
  5. #495
    May 2005
    Vienna, VA
    It's not just that. The font changed, too, so it'll basically have to be rewritten.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  6. #496
    Apr 2005
    Sonic: What version of iGlaunch are you using? I can tell by your screenie that indeed your grey borders are removed.
    2002 Honda CR-V
  7. #497
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Also, would you describe the trick you used to run iGLaunch (3.5) and iGMon simultaneously? I tried and got some funky glitches.
    I tried running the iGMon wizard on just iG (weird zoom errors on the speed and X in bottom right) as well as iGLaunch(error from igmon wizard) with no luck. iGLaunch works fine alone, but things get weird when I crank up iGMon on top of it. Also tried setting iGuidance window name to iGLaunch in the igmon.ini...
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  8. #498
    Nov 2004
    L.A.
    I don't know why you think Sb is "bloated". It's a bigger .exe (maybe?), but I think you can spare the couple 100k of HDD space. If you don't have a LoadSkin() command in the Startup= script then it will never run any of the button code, it will just embed and crop any window.
  9. #499
    Apr 2005
    RPM: OK, will give it a try. I just didnt want the extra memory footprint, and/or wasted CPU cycles.
    2002 Honda CR-V
  10. #500
    Nov 2004
    L.A.
    JIT: Your PM box is full. Here is my response to your PM...
    Quote Originally Posted by justintime
    What do I change this line to, for iG embedding...
    Embed(GooPsWindow:1000)
    Also, how on earth do I avoid the NO GPS dialog when testing this on my PC at home?!!
    2nd problem is easy, just set iG to use COM1 (or any comport that is not open by another app).
    Syntax: Embed([dir-name]:[time-out])
    [dir-name] = skin sub-dir. Example: GooPsWindow\GooPsWindow.ini holds the window title/class to embed and all of the nudging parameters.
    [time-out] = will continue running script if window not found after this many ms. 0 will wait for window forever. 1000 will wait 1 second.
    Here's all you need to do to "crop" iG3.
    I'd start with the BBiG skin if I were you. Rename it to iG3. Rename the BBiG.ini to iG3.ini. Open iG3.ini and delete every thing from the startup script except "Run(Run-iG.exe),Embed(iGMap:0)". Then open iG3\iGMap\iGMap.ini and read through that file to make it all work. You can delete all other graphics and ini's from the skin, you just need those 2 files and compiled auto-it script (Run-iG.exe) that launches "c:\Program Files\iNav\iGuidance\iGuidance.exe -nowarning".
    Edit: SbV3-P2 should not use any extra CPU or Memory that iGLaunch doesn't... they run the exact same code (Ol33l gave me his code which is how I started Sb). Sb just has more features and less hard-coded values so it can work for any application. If you don't have a LoadSkin() in the startup script, none of the graphics stuff will ever be executed at all. Embed() grabs any window and crops it, LoadSkin() overlays PNG graphics and runs scripts in response to hot-spots. Scripts can send keys, switch PNG graphics, run files, and play sounds. That is about all there is to Sb. None of it uses much CPU or memory really.
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
