Page 55 of 58 FirstFirst ... 54546474849505152535455565758 LastLast
Results 541 to 550 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #541
    May 2005
    Vienna, VA
    LOL. I don't know where he got igmon 3.1.1.117 from.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  2. #542
    May 2005
    Quote Originally Posted by b8bboi
    Thanks for the help...
    I right clicked on the application then went to properties then to the version tab....
    Now.. any ideas on the problem?
  3. #543
    May 2005
    Vienna, VA
    sebberry, do you have the latest version (2.0.1)? Those seem to be problems from the first beta.
  4. #544
    May 2005
    I am not sure which version I actually have... there is nothing to tell me... what date was 2.0.1 released?
    Thanks!
  5. #545
    May 2005
    Ok, I just downloaded the latest version, ran the config wizard and have the same problem
  6. #546
    May 2005
    Ok.. anyone know where I can get a ctrl+alt+del button??? I am in the middle of Edmonton right now and this roadrunner/iguidance combination is really ****ing me off
  7. #547
    May 2005
    Hmmm.. nobody has come across this problem before?
  8. #548
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    what exactly is your problem. ****ing you off isnt really a good way to describe what ur issue is. Whats your version of iguidance? Download the latest igmon. Run the config then tell us what the problem is and maybe someone will help
    Live mp3Car Facebook Chat
  9. #549
    Mar 2006
    Quote Originally Posted by sebberry View Post
    Quick question...
    Problems:
    1)I have been having lots of problems with IG 2.1.1 map displaying in the top left corner of the screen over the rr buttons
    2)Doing a city center search works until the point where you can either view it on the map or nav to the city - the confirm city window doesn't display correctly with igmon... and I can't back out without ctrl+alt+del
    3)Doing a POI search fails on the POI listing screen
    I am running igmon version 3.1.1.117
    Thanks for your help!
    If IG is covering the RR buttons, that leads me to believe that you're not properly embedding IG in RR. Are you sure you have the window title correct? Are you using skinbedder or anything else that would affect the window title? When you say the POI listing fails on that screen does it fail in RR only or does it fail when you run IG by itself? Do any of these things work without IGMon loaded?
  10. #550
    May 2005
    Ok, basically what has been happening is this:
    Looking up a street address is fine, the OSK loads up perfectly and I can enter a street name and address with no problems.
    However when I attempt to search for a POI or City Center, the confirmation screen does not load properly into the OSK skin.
    Well.... what I will do is post a screenshot.. I just upgraded to IG3 so the current version of iGmon won't work with that anyway...
    Will there be a version that does support IG3? I realy like the volume feature but with the UMPC version I do not need the big button mods.
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
