Page 56 of 58 FirstFirst ... 646474849505152535455565758 LastLast
Results 551 to 560 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #551
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by sebberry View Post
    Ok, basically what has been happening is this:
    Looking up a street address is fine, the OSK loads up perfectly and I can enter a street name and address with no problems.
    However when I attempt to search for a POI or City Center, the confirmation screen does not load properly into the OSK skin.
    Well.... what I will do is post a screenshot.. I just upgraded to IG3 so the current version of iGmon won't work with that anyway...
    Will there be a version that does support IG3? I realy like the volume feature but with the UMPC version I do not need the big button mods.
    The latest version does work with ig3 with the exceptions listed on the last 2 pages of this thread. i use ig3 and igmon together with no issues
    Live mp3Car Facebook Chat
  2. #552
    Jul 2006
    seattle
    i tried to implement igmon with IGv3 with roadrunner
    everything that I looks for works great!! muting no problem, auto switch screen also no problem.
    I also removed IGmon menu button and the magnification on the right corner thing.
    The only thing that bothering me is the screen that appears after destination is reached, it looks like a list or something.
    somebody know how to remove that?
    Cause I only need muting and auto switch screen from IGMON
    very good program though b8bboi
  3. #553
    May 2005
    Vienna, VA
    skuller, it's probably one of the dialog skins for ig2. Try setting OSKSupport = 0 in igmon.ini.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  4. #554
    Jul 2006
    seattle
    thanks a lot b8bboi, i'll update the result soon.
  5. #555
    Jul 2006
    seattle
    works like charm. thanks a bunch b8bboi
  6. #556
    May 2005
    Vienna, VA
    no problems.
  7. #557
    Jan 2004
    NYC
    Quote Originally Posted by skuller View Post
    how did u remove the menu button and magnification and other menu's that igmon uses....i just upgraded to IG 3 myself
    Im asuming that all IG(UMPC) menus and keyboard are good for our 7" sceens, so we can just use igmons mute and autoswtich features??
    [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
    [iGmon]
    Download MP3 MixTapes
  8. #558
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    b8bboi, under what condition/criteria did you make iGmon to always on top? With the beta in iGuidance Native thread, iGmon "think" RR is in other mode than GPS. Is there anything we can make the 2 works together?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  9. #559
    May 2005
    Vienna, VA
    matrixpc, I check for the the visibility of the "iGuidance" window to determine whether iguidance is on top or not so yeah, there might be a problem with your implementation. I'll need to figure something out.
  10. #560
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by b8bboi View Post
    OIC, yeah, what available on GPS screen is RR's form, not iG.
    How about this option.
    I'll set a variable in RR as a flag. You check this flag, if it set to true, push iGmon to top, otherwise search as normal (for compartible with other FE porting of iGmon.)
    Obviously, you can use Windows API IsWindowVisible with iG windows handler to check if RR is in GPS screen or not. iG windows handler is iGhwnd in the iG Native Beta release 8/24.
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
