Page 8 of 58 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 571
Thread: iGMon - Solution for integration between iGuidance and Road Runner (I hope)
  1. #71
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Please post your mod. I am interested.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  2. #72
    Feb 2004
    North Aurora, IL
    its been posted on the first page
    I wish i knew how to do fiberglass work...
  3. #73
    May 2005
    Vienna, VA
    Yeah, like I said in my first post, it doesn't work with SkinBedder yet. The issue is SkinBedder hides the iGuidance window completely and iGMon won't be able to detect when iGuidance is "visible." I might work up a fix for this but I won't promise anything.
    gonthorn, glad to hear that it works with 2.1.3. Please let me know what features you've tried out that work.
  4. #74
    Jan 2006
    Features that work with 2.1.3:
    enter new address via OSK skin
    Picking Favorites
    Turn Popups
    Auto switch to GPS screen when iguidance is talking
    Thats all I tested so far, just drove around the block ;p
    LSX VOID MOD <------ use this to allow IGMon to work with the void skin
    Those of you who want to use this with LSX VOID, here are the files I modified to make it usable, it gives you audio control when in fullscreen GPS (at the cost of removing the flash speedo) and is fully compatible with igmon
    replace the following files (note, this is set for 800 X 600 only)
    The coords.ini replaces the coords.ini in LSTOOLS\SB2.9\IGUIDANCE\
    The .skin files, and the ExecTBL.ini should overwrite the Skins\LSXvoid\ files of the same name
    Just unzip the attached file and overwrite as decribed above
    Hope that helps
    Attached Files Attached Files
  5. #75
    May 2005
    Vienna, VA
    Civic and all, GOOD NEWS, GUYS!!
    I was able to get iGMon to work with SkinBedder. I'll post an update sometime tomorrow. Stay tuned!!!
  6. #76
    Nov 2005
    Quote Originally Posted by nameeri
    Honestly its worth spending some $$$ and upgrading your hardware. Your OS isnt even supported at all by MS and hasnt been for the last 4 or 5 years. You really should upgrade, im sure you can find something cheap on ebay.
    Thanks for the encouragement everyone. Anyways, I just bought this laptop for the touch screen. Its going into a $400 car so the $60 I spent on a touchscreen laptop is all its getting. But seriously, anyway, Panasonic canada had an xp driver for the laptop model after this one and I was able to get it working on this version in Xp. So I am writing you from XP on a POS laptop with working touchscreen so you can ignore my first post (which you already have done). Total investment for complete system will about $100 total.
    My other car system (for a car worth a system) is a AMD 2400+ Mobile undervolted that has the usual other bells and whistles.
  7. #77
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Civic03
    Hey b8bb0i, would this work with the LSX VOID skin? He uses his own version of IG so I'm not sure if I can use this without messing that up. I really want to use this and hope the two can play together somehow.
    the version of iG thats included in my skin is purely for astetic reasons. You dont have to use it. The version of skinbedder thats included with the skin is also not an absolute requirement but by default this is how and what the skin is setup to work with "out of the box".
    When did this thread pop up? havent checked out the video yet, actually thought this was a 6month old post, had to check the dates. But from what im thinking this is pretty damn cool. Will have to download and take a midnight drive to test this all out.
    beer replenishment fund
    mp3car live search
  8. #78
    Aug 2003
    Chicago
    Quote Originally Posted by gonthorn
    Picking Favorites
    Turn Popups
    Hope that helps
    can you please mark any changes you've made, as im always updateing the ExecTBL.ini file, and i would wrather not have people copy your changes ontop of mine. I would much rather include your changes to my local files and whenever i update everyone gets the changes. For example the version of the ExecTBL.ini file you posted is older than my local version that will be released shortly and i dont expect everyone to compare the files and figure out what they need to copy and paste.
    Also if you can provide a short discription on why you did certain things.
    Like i dont understand removeing the speedo in gps fullscreen to add audio buttons? There are audio controls on the main gps screen, so now they are both basicly the same? Is this a personaly choice or dose this have something to do with igmon support? Im not sure as i havnt downloaded anything yet.
    mp3car live search
  9. #79
    May 2005
    Vienna, VA
    liquid_smoke, gonthron and civic, my iGMon version tomorrow is gonna work with LSX Void without any changes to LSX Void at all. There'll be a little more configuration to do on iGMon's part, though.
  10. #80
    Aug 2003
    Chicago
    Quote Originally Posted by b8bboi
    cool,
    i still havnt tested out any of the files yet, but i can make changes and add in support for this, i just need to know what it is that makes it so its not compatible? Is this just a skinbedder issue? The modified iGuidance.exe? (actually its the same file as JustInTime's Big Button mod except its a red version and i added a different icon for where u are on the map)
    if you arent using skinbedder, what are you using to remove the file menu in IG? Honestly this is the only reason i actually use SB.
    Looked at the video, NICE!!!!
    i get tired of switching back and forth to gps everytime i want to check what street im supposed to turn on. And the auto volume is my ig wish come true
    mp3car live search
  1. iGuidance NATIVE in Road Runner
    By skippy76 in forum Road Runner
    Last Post: 05-01-2007, 02:10 AM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  5. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
