Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 91 to 100 of 112
Thread: Flash Guages including source code
  1. #91
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    My trunk is clean, actually there is no trunk, it's a hatchback. My subs fill most of the space, and my toolbox takes up the rest. (The tools are what move when I corner...)
    I used to have a Toyota Tercel SR5 and it had a clinometer (google it: )
    Something like that would be cool too. Not sure how to calculate or 'simulate' that though...
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  2. #92
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by monkeyracer View Post
    GPSSPD and GPSHDG will work for those guages, but you would need an autoit script to store the speed and heading one second ago to compare to now and display a new variable, which you can put into flash as dynamic text with that variable.
    here's some inspiration pics:
    (the left right and brake/gas part)
    (bottom left corner)
    Maybe like this, but flipped so that left is on the right side, and accel is on the bottom. That way when you turn left, the pointer moves to the right (like all the stuff in your trunk) and if you brake hard the pointer goes to the top (again, like the stuff in your trunk...) if you are accelerating AND turning, the pointer will not be on the line.
    no autoitscript shall be neccessary. I can read the label into a sprite which runs the formula once per second directly in the flash script. My only real question for your accellearation example is how would one determine the max value in the equation. I mean obviously different cars have vastly different rates of accelleration. Shall i just use a static MAX, user-definable max or what?
    Live mp3Car Facebook Chat
  3. #93
    May 2007
    Lakehood, CO
    Quote Originally Posted by GizmoQ View Post
    Most cars can't do more than 2 Gs generated from the driveline or braking, most tires can't handle more than 1.6 Gs laterally, an alcohol funny car does about 4.6 Gs in a 300MPH 1/4 mile run.
    Bottom line if you're talking about accel/decel and lateral: a 2G limit ought to cover you all the way around for 95% of cars on the road today.
    I'd say 2G's would be about right.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  4. #94
    Newbie DaveDevil's Avatar
    Jul 2007
    Ok, i have understanded how to pass informations from the flash gauge to a plugin in roadrunner.
    but the update even one second is too slow for showing the speed, rpm, etc.
    how can i make a gauge updating at least 4 or 5 times per second?
    i'm trying to make working Dalailama's project... so please help me, his skin is really beautiful!!!
  5. #95
    Jul 2007
    for this, i think you can use a gyroscope sensor, like this:
    http://www.robot-italy.com/product_i...roducts_id=772
  6. #96
    May 2006
    Agueda
    Hi
    some one can explain me how I can make a guages like this?
    is possible give some source code about change gauges? in VB or flash...
    I see some zip files but I dont how software for manage .swi, because I like change code for read source for RS232..
    best regards
  7. #97
    May 2007
    Lakehood, CO
    Quote Originally Posted by filjoa View Post
    hi
    is possible make an plugin like this last (blue skin) but with backgraund of new nissan gtr?
    +- like that
    and
    regards
    Hi
    best regards
    If you have the source in swi, check here:
    Quote Originally Posted by JohnWPB View Post
    You can also try Softlink's SWF Decompiler, and convert the SWF directly to FlA files. They have a trial version to test it out.
    If you don't have the source, then save the image into photoshop, and make the different layers, then in flash, import the image in it's separate layers and animate it accordingly.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  8. #98
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    A definable value would be fantastic! For instance if you make the scale for a Corvette's capabilities, the indicator would barely move on the scale for anyone driving a Geo Metro This would allow the user to cater the gauge more to their car, so when they "floor it" the indicator will be very close to the top of the scale.
    As for turning, if you were doing donuts in a parking lot, you would want it pegged to one side. What type of scale I really don't know on this one. Just that it needs to be based on how fast your heading is changing. if you are on a straight road going North East, it would stay centered. If you get to a gradual curve in that road, your heading gradually changes, thus the indicator would "sway" slightly to the direction of the turn. Basically just mimicking the force you feel when cornering.
    I had something very simple in mind for the gauges. It should really just be the indicator. This way an image could easily be made to match what ever skin and style it is used in.
    With it done like this, the gauges could be placed over an image of the top view of your car, over a fancy graphic gauge background or whatever anyone wants.
    Making the indicator an external PNG would be even better! This way it gives the skinner complete control over the look of the background, as well as the indicator ball, needle, pointer ect.
    Lastly, the number it is basing itself off of for the calculations needs to be a RR label. Meaning, for the acceleration / deceleration gauge, if you are accelerating at 8 MPH in a second, then "+8" needs to be placed in a label that can be used in the skin.
    This is a very quick thrown together image, to show one example of what can be done. All that is needed is the SWF's to be overlaid over the top of the bars, so the indicators appear.
    My Fiero Build Thread
  9. #99
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    hi
    +- like that
    and
    regards
    While it's not flash, I'm using dashcommand by palmer performance to make a similar screen (not finished yet):
    You need an elm obdII interface for enigne/PCM info though..............
    Sorry for the little bit of off topic guys. Just looks like what he's looking for.
    Now back to your regularly scheduled thread....................
    Leonardo Da Vinci
  10. #100
    May 2007
    Lakehood, CO
    I agree with john, someone driving a z06 will have a totally different gauge appearance than my N/A PT (read: slow a$$ car) if I floor it, it will be all the way to the limit of the gauge or close, and when the Vette driver floors it, the same will happen, but his limits are higher. There was a great diagram in the user manual for GT2, but I don't have that with me right now. I might photochop something later to show what I was thinking the gauge would look like.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  1. Need spectrum analyzer source code
    By XPLORE in forum Software & Software Development
    Last Post: 12-07-2001, 10:19 AM
  2. MPXPlays Source code is available!!
    By Fosgate in forum Software & Software Development
    Last Post: 05-30-2001, 05:18 PM
  3. c++ LCD source code
    By mprover in forum Software & Software Development
    Last Post: 01-19-2001, 03:32 PM
  4. Keypad plugin source code
    By brandondere in forum General MP3Car Discussion
    Last Post: 12-28-2000, 09:10 PM
  5. If you use the winamp LCD plug-in, do you need a source code??
    By SSJGogeta in forum General Hardware Discussion
    Last Post: 01-03-2000, 08:36 PM
