Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 112
Thread: Flash Guages including source code
  1. #41
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by kpjuk
    Thanks Happpyg,
    Quattro, you need to try them out. I run mine on an MII and yes they jump, but this is because I have set the frame rate to 2 frames per second, so the updates only happen every half a second. Depending on what you are driving you may or may not have a problem. My MII runs pretty close to 100% full time with 5 clocks on 1 screen, so I can't tell if the jumps are due to lack of cpu cycles, or anything else. The data from the GPS only comes in every second anyway, so if you are accelerating hard in a fast car, you are always going to get a jumpy effect.
    Hope this helps
    KPJUK
    I know that you only get updates from the GPS every second so thats why you get the jumping. But if the needles were actually coded to go in a circular motion from on point to a nother it doesn't matter if the updates are every 1 seconds. it'll still sweep around the dial.
    So if your telling me they jump in your setup then most likely its isn't coded the way I want it. I'll probably have to do it myself.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #42
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Sorry Quattro, I didn't understand fully your question. If do you do get to code them, I would be interested. I have only know enough Flash to hack at other developers code. These clocks matched my skin, but killed my computer, so I have learned enough from these threads to change them a little.
    Good luck with the project
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  3. #43
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    I think what he means is even though the (nmea) speed updates once a second, he wants to update the clocks at say 10fps, in which case he needs to store the old speed, subtract that from the new speed to get the (+/-) difference, and add (fps/100) of that value to the current needle value........
    eek.
    like this
    old speed 40mph
    new speed 50mph
    difference =10mph
    sweep value=10mph / frame rate (1mph)
    needle position = needle postion+sweep value
    The above has errors, see if you can spot them........
    Lez, more widely known as flez1966
  4. #44
    Low Bitrate Flappy's Avatar
    Jun 2004
    Netherlands
    How about this:
    A speedo (0 to 100km/u or 0-60mph). When u start driving from zero, a counter starts. When u reach 100km/u, the counter stops. Everytime u are back to 0 km/u, the counter resets, but remembers the fastest time. This can be very handy for tuners, but it's also a cool feature just to play with...
    Is this possible?
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
  5. #45
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by Flappy
    How about this:
    Is this possible?
    err, in software yes, but I cant comment on the flash etc I have not even downloaded this!
    but its simple in software.
  6. #46
    Dec 2003
    New York
    How about this:
    Is this possible?
    If your using the gps signal for your results then this is not a good idea. You might not get update from the gps at exactly 60mph, the next update might be at 75 so, the timer will record until then. So this won't be very reliable.
    Installed
  7. #47
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    It would be up to a second off at the worst, but still in the ball park.
    OBD-II info would be your best bet, but i'm not aware of any integration with flash in that department.
    Beer is proof that God loves us and wants us to be happy — Benjamin Franklin
  8. #48
    Dec 2003
    New York
    @DiNASTY
    quick question, does your flash gauge in Flashdeck have a sweeping motion from one position to the next or does it jump after every update?
    Installed
  9. #49
    Low Bitrate happpyg's Avatar
    Feb 2005
    Bunbury, Western Australia
    Quote Originally Posted by RS200Z
    Hi happyg, is your download link in the first posting updated with the 2fps version?
    Yes, I have just recently updated it & added the transparent versions too (same gauge with no background or gauge body)
    Semperon 3200+/512MB/ Seagate SATA2 120GB
    10.2" Xenarc/ Netgear USB Wireless
    M2-ATX/RadioShark
    BU-353 GPS Receiver
    http://www.happyg.mine.nu/carpc/index.html
  10. #50
    Mar 2005
    Concord, California
    Quattro, yes it does sweep.
  1. Need spectrum analyzer source code
    By XPLORE in forum Software & Software Development
    Last Post: 12-07-2001, 10:19 AM
  2. MPXPlays Source code is available!!
    By Fosgate in forum Software & Software Development
    Last Post: 05-30-2001, 05:18 PM
  3. c++ LCD source code
    By mprover in forum Software & Software Development
    Last Post: 01-19-2001, 03:32 PM
  4. Keypad plugin source code
    By brandondere in forum General MP3Car Discussion
    Last Post: 12-28-2000, 09:10 PM
  5. If you use the winamp LCD plug-in, do you need a source code??
    By SSJGogeta in forum General Hardware Discussion
    Last Post: 01-03-2000, 08:36 PM
