Here is the KB layouts for IG3.
Numberpad layout.
Yes, KBD is huge in the UMPC version. Too big if you ask me!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Numberpad layout.
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Win7 with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Screen:Xenarc 700TSV
The Florida Meets Thread
Originally Posted by john1701
Thanks for posting this! I literally just finished getting this working before I left on a long trip. IG3 is nice also.
I managed to get it running in a window which works somewhat independently of RR. With IG2.1.3 it was nested inside the window of RR so that it wouldn't spill out. Now, everytime I go back to the External GPS page in RR, it tries to load up another instance of IG although one is already running. Of course the COM port is already being used by the already running copy of IG, so the new instance of IG doesn't work. This forces me to close the new IG window everytime. It's quite annoying when you're driving to constantly have to close the second IG window that opens. Did I do something wrong? I don't remember this problem with the old IG. Seems like it's just launching multiple copies of the same IG3.EXE made from AutoIT.
Thanks again!!!!!!!
think you missed something. go back and check everything. If it still does it, post what you did.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
I did precisely what the instructions said.Originally Posted by john1701
I used AutoIT to make a script compile into an EXE named IG3.EXE. Then I run Skinbedder. Then in RRConfig, I set the External GPS application to be SKINbedder.exe (not the actual iGuidance EXE --- this step wasn't mentioned in the instructions above). Also, I'm using the UMPC version, not the regular version.
Well, if I tell RR to run IG3.exe instead of Skinbedder.exe, it seems to work inside the window properly.
This begs the question, why is skinbedder even necessary then?
i was planing to use skingedder to get iG3 work and look more car friendly,but i feel like,it is cain good the layout and menus,all i did is use skinbedder to avoid seeing the window toolbar,and then just change the graphics of the menus,also i did discover that you can add or remove buttons in the menus,this way you can customize them.any ways if someone wants to take a look to some shots go here.
night skin wmp11 1st idea,good or bad??
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
uptpilot
skinbedder keeps you from seeing the menu bars. It sounds like your problem is that you still have the window name as "iguidance" in rr. Change it to skinbedder and have it launch the skinbedder exe and it should embed properly.
no offense to anyone, this is a guide, not a step by step installation. I will not spoonfeed. donde beat me to what I think your problem is... and el camino explains why skinbedder is used.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
