Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 76
Thread: one-click mp3 to flash drive. Anyone interested
  1. #21
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Good work man!
    I will get it installed and test it as soon as I can. Will be a great addition to RR.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
  2. #22
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    been researching all week for a bluetooth solution. Seems windows is FAR behind with the technology than apple. As far as i can tell there's no "clean" method of establishing the bt connection then transfering the file via script or external program. There is also no way (as far as i know) to open the bluetooth neighborhood window. I've tried opening shortcuts, rundll btneighborhood.dll and a few other methods to no avail. The ONLY way i was able to automate it was through mouseclicks and quite frankily thats not gonna work as efficient as need be. I'm gonna keep tryin new ideas but if anyone knows of any ways to establish the connection OR open the bluetooth neighborhood to automate a solution i'd definitely appreciate it!
    Live mp3Car Facebook Chat
  3. #23
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Sonicxtacy02
    New version. updated first post. Blue zx3 pull the file from my site and update your mirror please
    Updated...
    Sorry to here that...I would give it a try too if I could but I don't have any bt devices so it would be kinka hard to find a solution that I could suggest...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #24
    Just downloaded the file and the config has no settings.. i.e nowhere to configure anything.
  5. #25
    Woodbridge, VA
    Blog Entries
    55
    afraid i dont know what you mean.
    -extract the rar
    -Open the readme file in the main folder. It tells you where to place everything. The mp3copy folder NEEDS to be in C:\program files\
    -After youve completed all the steps in the read me go into the mp3copy folder and run mp3copyconfig.exe. Here's where you create your settings. It saves to the .ini in the same folder.
  6. #26
    Typed that last question in a hurry..
    The select send method and the drop down box is blank.. Not sure if thats right?
  7. #27
    Woodbridge, VA
    Blog Entries
    55
    no it definitely shouldnt be that way. Lemme check to see whats causing that. Are you sure you have the program int he right path (c:\program files\mp3copy)?
  8. #28
    Woodbridge, VA
    Blog Entries
    55
    i've tested the version thats on my site and it works fine provided you have the path correct. You dont even have to have an .ini file in the folder just as long as its where it needs to be. The setup folder doesnt go there just the mp3copy folder.
  9. #29
    It was in the right folder.
    I've just deleted the mp3copy.ini file and tried again and it seems fine now.
  10. #30
    Woodbridge, VA
    Blog Entries
    55
    thanks for the info. I guess i should package it with a "default" ini instead of a blank one.
  1. 2.5" drive help?
    By IntellaWorks in forum General MP3Car Discussion
    Last Post: 10-03-2005, 08:36 AM
  2. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  3. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:24 PM
  4. Flash hard drive on ebay
    By Mp3 V in forum General Hardware Discussion
    Last Post: 02-16-2002, 12:39 PM
  5. Car MP3 CD Radio plus hard drive
    By mp3designer in forum General Hardware Discussion
    Last Post: 03-27-2001, 01:27 PM
