Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 76
Thread: one-click mp3 to flash drive. Anyone interested
  1. #31
    Probably
    Also - I can't figure out the code to use on the button, can you help with this?
    Cheers
  2. #32
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Focus Dan
    Probably
    Cheers
    wow didnt realize there was any unanswered questions. Did you mean the button in rr? The code for that would be
    "RUNQ;C:\Program Files\mp3copy\mp3copy.exe"
    Live mp3Car Facebook Chat
  3. #33
    Woodbridge, VA
    Blog Entries
    55
    Sounds very good!
    Could also be used to copy favourite tracks to another local folder - creating a playlist.. kinda..
    if that makes an sense... lol
    Old post but i wanted to point ur attention here:
    Ratings plugin
    That program saves favorite songs to a playlist (.m3u) If interested post there.
  4. #34
    Newbie polomaniac's Avatar
    Apr 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    so i was driving in my car this morning and a set of 3 songs i love came on back to back to back. Old favorites! I got to work and wanted to listen to them on my work pc that has no music on it. I opened my computer and transfered them via copy paste, but it got me thinkin of whippin up a script that would do this for me. I've got it done.. and pretty easily via autoit and a winamp plugin. I added a button on my rr audio player skin that executes the program. The program in itself reads whatever file is currently playin in winamp (via the plugin) then sends that file to the destination folder (my removable media). Its working just fine for me right now, but i started to wonder if anyone would find this useful. If so, i'll create an .ini for the program that will read source and destination mumbo jumbo and could also make it so the mp3 would be sent directly to a networked pc or ftp. If anyones interested, let me know. If not... hey more goodies for me
    EDIT
    New Version 1.2Download here
    http://www.sonicxtacy.com/mp3copysetup.rar
    Mirror Site : ftp://myspotontheweb.no-ip.org/RR_Ut...3copySetup.rar (thanks to Blue ZX3)
    1.1 Only changes are the config utility now preloads data from rr.ini so that you dont have to redo EVERY setting each time you run config
    1.2 Everything 1.1 had PLUS new on the fly mode. Allows you to choose whether your copying file or album without going to the config if you so choose. A box pops up where you can select file or album. Overwrite existing files after you back up the .ini settings.
    none of the links is working overhere . sounds really handy when a friend likes some songs while driving !. i've also pm'ed you.
    sjors
  5. #35
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by polomaniac View Post
    sjors
    responded to your pm. And the links are working for me
  6. #36
    Apr 2006
    hey i pm-ed you about some new code i wrote.... with this there's no need anymore for a winamp plugin. only i don't know how yet how to make a copy to ftp or bleutooth yet...but let me know if you're interested...
    sjors
  7. #37
    Apr 2006
    Sonicxtacy pls read you pm's. i'm waiting for your approval to release my program... your idea but no need for a WinAmp Plugin any-more.
    hope to hear something soon
    sjors
  8. #38
    Woodbridge, VA
    Blog Entries
    55
    i did read it. you talkin about the lpt plugin or adding on to mp3copy? i sent you the source files for mp3copy. Release it whenever u want to FTP should be able to left the same. Bluetooth is pretty much a dead duck.
  9. #39
    Apr 2006
    ok i'll release it within an hour... just need to write the read me but i was talking about mp3copy...
  10. #40
    Apr 2006
    ok, in allience with Soncitacy02 i release Winamp Copy
    download link:
    http://members.lycos.nl/polomaniacessen/down/
    it has got all the function of MP3 Copy except the bluetooth option.
    furthermore you do not need any WinAmp Plugin any more.
    There are several 2 main commands:
    -copy File (copies a single file)
    -copy Dir (copies the complete dir were the file playing at the moment is found)
    There are 2 supported copy methods:
    - Normal copy to another path on you computer. If there is not enough space on the
    defined target path a msgbox wil popup.
    - FTP, send the song directly to a FTP server
    the FTP-Password will be stored encrypted in WC_config.ini. If Winamp copy
    is executed from an other physical partition then the last time, the password
    can't be decrypted anymore. so you will have to set it again or move Winamp
    Copy back to it's last partition.
    NOTE: passwords can be manually added in plain text in WC_Config.ini but it will
    be visible for anyone who opens WC_Config.ini
    Both methods seem to work fine, but if you do got any problems please post them in the
    mp3car.com forum. You can find a link to the topic on to of this file.
    For functionality with RR some 'target line' commands are availeble
    cf.exe this will copy the current playing file, in winamp, to the Specified directory
    cd.exe this will copy the complete directory off the current playing file.
    !!! BE CARFULL WITH /CD, EVEN IF A DIR IS SOME THOUSENDS OF MB'S LARGE IT WILL COPY IT IF
    THERE IS ENOUGH TARGET-SPACE. BUT THE COPY PROCEDERE CAN ONLY BE STOPPED BY ENDING
    THE PROGRAM WITH TASKMESSENGER!!!!!
    Tested with WinAmp 2.81 and higher.
    an example to use in your RR skin:
    "RUN;C:\cf.exe;Copyfile"
    hope you like it
    note: i've made it using command line tags.... but rr can't handel them :S it will just freeze up... got any ideas Guino?
  1. 2.5" drive help?
    By IntellaWorks in forum General MP3Car Discussion
    Last Post: 10-03-2005, 08:36 AM
  2. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  3. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:24 PM
  4. Flash hard drive on ebay
    By Mp3 V in forum General Hardware Discussion
    Last Post: 02-16-2002, 12:39 PM
  5. Car MP3 CD Radio plus hard drive
    By mp3designer in forum General Hardware Discussion
    Last Post: 03-27-2001, 01:27 PM
