Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 76
Thread: one-click mp3 to flash drive. Anyone interested
  1. #41
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    i just now saw this? What is your version written in? VB or what? I'd like to take a look at the code to see if we can do anything about the command line issues.
    Live mp3Car Facebook Chat
  2. #42
    Newbie polomaniac's Avatar
    Apr 2006
    yep completely vb... and command line works fine... just not with RR.
    when using the run command it can't cope with the neede space between the .exe and the used command (ex. /cf)
  3. #43
    Woodbridge, VA
    Blog Entries
    53
    ah ok, i'm tryin to build this program to function seemlessly with rr.. to appear as if its a built-in function. Your program is more stand-alone oriented. That being said you should definitely post it in the general software forum.
  4. #44
    Apr 2006
    yep that's true. some of my friends liked it when i asked them to test it on their machines and asked if they could use it to easyally copy playing files to flash-drives off friends of them while beeing over for a drink. so i made it a stand-alone program. i'm now thinking of makin an extension plugin which does the same thing, the only problem is that there will be ANOTHER file which u need to use and to define in each skin :S but feel free to use any of my code
  5. #45
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    How does the confirm popup work in RR?
    I've copied the enclosed skins into my skin folder, copied the two ExecTBL.ini lines into my skin folder's ExecTBL.ini (which I understand to be the same as putting it into the main RR ExecTBL.ini file, just more skin specific) and put the following in the command line into a button per the post above:
    "RUNQ;C:\Program Files\MP3Copy\mp3copy.exe"
    Also, here's the .ini file located in C:\Program Files\MP3Copy:
    [mp3copy]
    SendMethod=FlashDrive
    WaitTimeTrack=3000
    CopyMethod=file
    DestinationSite=G:
    FTPSite=
    BTsite=
    SendConfirm=True
    NoConfigSend=False
    How does the plugin call for the confirmation skin to pop up in rr?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  6. #46
    Woodbridge, VA
    Blog Entries
    53
    the plugin needs to be updated. basically the program is looking for rr.exe instead of roadrunner.exe (recently changed). I'll post an update later.
  7. #47
    Woodbridge, VA
    Blog Entries
    53
    New version released. Check first post.
  8. #48
    Aug 2006
    Sun Diego
    Awesome! Works great. Thanks!
  9. #49
    Woodbridge, VA
    Blog Entries
    53
    program updated (not neccessary if your plugin is working though). Check post 1
  10. #50
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Hi Sonicxtacy02...I have DL MP3 copy. I read the readme file(also the whole thread) and have a couple of questions.
    1. -Copy contents of Winamp files folder to C:\Program Files\Winamp
    Where are the contents of winamp files to be copied to winamp folder. Is it included in the .rar file?
    2. In the adobe file (Winamp/plugins folder), there are a lot of options. Template file, Not Playing file, Output file, Popup Format, speech format. Which ones need to be configured and any specific configuration?
    Thanks.
  1. 2.5" drive help?
    By IntellaWorks in forum General MP3Car Discussion
    Last Post: 10-03-2005, 07:36 AM
  2. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 03:37 PM
  3. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
  4. Flash hard drive on ebay
    By Mp3 V in forum General Hardware Discussion
    Last Post: 02-16-2002, 11:39 AM
  5. Car MP3 CD Radio plus hard drive
    By mp3designer in forum General Hardware Discussion
    Last Post: 03-27-2001, 12:27 PM
