Page 4 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 40 of 120
Thread: DJiK's Jump-to-File External Control Plugin, v0.99b [BETA]
  1. #31
    Mar 2006
    THANKS!!
    I do want to make it load when I press the original search button in roadrunner. I'm not sure how to do that, do I change the "Searchfiles" command to something else?
  2. #32
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by Mushdawg View Post
    THANKS!!
    Yes... I'm still writing a detailed help file on how to do that.
    Short version:
    Pick an unused button in any skin (incl. SEARCHFILES),
    Change the code to something like this:
    Code:
    B06,629,214,150,80,"RUN;D:\Programs\Road Runner\Skins\ZdGrey.Copy\Extra\JTFEP.exe"
    Basically you're looking to change anything from the last comma (,) onwards.
    Obviously the path in your case has to point to the right place.
    Also, for convenience porpuses, rename the long file to something shorter like 'JTFEP.exe'
    If you're going to move the .exe, don't forget the 'Images' folder.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  3. #33
    Mar 2006
    NICE!! thanks a lot.. I knew it was something like that, Im jus not familar with syntax for the commands..haha RUN is simple enough for me
    Thanks!~
  4. #34
    Mar 2006
    hmm I dont really care about this that much, but maybe someone else would like the capability to be able to double click the song (or touch) the song to play it instead of the highlight n play. both functions not take away one
    uhm.. actually probably no one cares about that
  5. #35
    Apr 2005
    Touching the song selects it so that the user can either play it or enqueue it.
    Doubleclicking on a touchscreen is a tough thing to do.
    I don't want to frustrate anyone.
    If somebody really wants/needs to have doubleclick enabled, I'll give it a try. Otherwise, I don't see the point, either.
  6. #36
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    DJiK, one request: in the current 'integrated' version, after pressing play is there a way for jtf to hide and rr to go back to the audio player screen?
  7. #37
    Apr 2005
    Quote Originally Posted by replicant View Post
    Yes.
    The file from the post above would close JTF after pressing play.
    If you've integrated it with RR using the "RUN" command (read post #32), RR would go back to the previous screen after pressing play.
  8. #38
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    DJiK, Wow, id didn't expect you to go get a different version of Winamp on my account! I appreceiate the help though, as this looks like it would be a FANTASTIC replacement for the weak playlist and search capabilities in RR.
    I removed Winamp, went and got a clean copy, didn't even use the one I had here, and still no go
    Followed your dirrections to the T and all is well till I try to configure the plugin. as soon as I hit the Config buton, thats when everything locks up.
    Here is a snapshot of my screen: (I drug the CPU meter into the frame to show I was running at 100%, on a 3.4 Ghz P4 none the less...This is my desktop PC, NOT the CarPC running at 3.4Ghz! )
    I am going to bite the bullet and go for the more bloated Winamp 5.x and see if I can get this to work.
    I'll let you know how it goes
    My Fiero Build Thread
  9. #39
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Just DL's and installed Winamp 5.24, and all is well! Works like a champ. Now to get off the forum and test it all out.
    Ya know, this is all I needed yet ANOTHER app to have to skin!!
    First I had to skinn RR, then IGMon for iGuidance, and then iGuidance itself with ResHacker, and now this.... This CarPC stuff is sure sucking up my extra time!
    Thanks for a great program!
  10. #40
    Apr 2005
    Quote Originally Posted by JohnWPB View Post
    It's weird how it doesn't work in Winamp 2.95, but anyway...
    If you've reinstalled the JTF plugin after installing Winamp 5.24, then it shouldn't give you any problems with hibernation/suspend.
    You'll find that it works just as well in your CarPC as v2.95 did.
    As for skinning... I haven't written anything up, but hopefully it's self explanatory:
    Keep all file names and image sizes (pixel-wise) the same.
    Thanks for trying out my program!
    If you experience any technical difficulties, you know where to post.
    I'll do my best to release v1.0 and all of the related documentations by the end of this week.
  1. File Sync Beta Testers Required
    By ric355 in forum EZSync
    Last Post: 07-01-2005, 02:20 PM
  2. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
  3. jump to winamp plugin?
    By metlok in forum Software & Software Development
    Last Post: 05-12-2002, 11:24 PM
