Page 1 of 12 1234567891011 ... LastLast
Results 1 to 10 of 120
Thread: DJiK's Jump-to-File External Control Plugin, v0.99b [BETA]
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Lightbulb DJiK's Jump-to-File External Control Plugin, v0.99b [BETA]
    One thing the mp3Car forum has taught me, *****ing and complaining will only get you noticed,
    Doing something, will get you remembered!
    Having said that, Ladies and Gentlemen, I present to you: Jump-to-File External Control (v0.99b):
    Description:
    An external application that manipulates the original JTF plugin which comes standard in Winamp.
    Features:
    • View, select, and filter the song list
    • View, select, and manage the queue list
    • Passenger friendly -- keyboard access to all functions
    • Driver friendly -- large buttons, list arrows, and an OSK
    • Winamp / Other Winamp-based Front Ends compatible
    • Skinnable -- Custom Images in Any Location
    (Red = under development)
    Instructions:
    • Pre Installation:
      • Download the latest JTFE Plugin here -- v.097.7 (Build 49)
      • Open Winamp
      • Focus on the main Winamp window
      • Press 'Ctrl+P'
      • On the left panel: Under 'General Preferences' click on 'Jump To File'
      • Choose the Enqueue Options (the very first tab)
      • On the top right: Press 'Defaults'
      • On the left panel: Click on Skins (¾-down the list)
      • Under 'Installed Skins:' Choose 'Winamp Classic' (Thanks edrex for discovering this bug!)
      • On the bottom left: Press close
    • Download:
      • Download 'JTF Full Control v0.99b.zip'
        Thanks UrbanSoot for the hosting space!
      • Unzip the contents to any folder on the hard drive
      • Make sure the 'Images' folder is in the same folder where the .exe file is
        Like this:
    • Very Important Step:
      • Be sure Winamp or RoadRunner is on!
    • Run the Program
    For Your Consideration:
    This program is a beta stage; please tell me of any unexpected errors you come across.
    JTFEC was created to manipulate a Winamp plugin, not the other way around.
    Attention Skinners:
    When unzipping, be careful so that my images don't overwrite your newly created images.
    Although a help file for skinners will be created, here are some general notes on the 'skin.ini' file (found in "Images\") for the time being:
    All images can now be .JPG, .BMP, and .GIF (let me know if transparent GIFs work).
    Buttons [1] through [20] are static, to know what each does, read the remark inside the file.
    Buttons [21] through [79] are custom. You can create any button you wish.
    When creating buttons, be sure that their order is consecutive (uninterrupted), i.e. [21], [22], [23], and so on... Don't skip a number.
    Moreover, you can create strings instead of keys, for example, if you like a particular artist or song, you may write the entire string into a button. You could create a heart icon and make it type "LOVE " into the plugin.
    If the image's size does not equal the width and height you've specified, the image will be resized accordingly, automatically.
    For the plugin to work, you must have values under the [General], [SongList], [QueueList], and [SearchText] sections.
    Be careful when assigning a button for [6] "Move After Current": If pressed, it'll put the selected song to be next in the current playlist and will turn shuffle off!
    Compatibity:
    Thus far, this program had been tested on WinXP Pro SP2, Winamp 5.24 Std. & Pro., and JTFP v0.96ff & v0.97.7 (Build 49).
    If you have a Win64 machine, let me know if it works on it.
    Screenshots:
    The program should look like this:
    It is currently skinned to match the ZDGrey skin.
    Bugs Fixed (starting from v0.7a):
    • Fixed in v0.71a
      • Works correctly right after loading Winamp
    • Fixed in v0.72a
      • After loading 10+ items in queue, it arranges the list properly
    • Fixed in v0.91b
      • OSK numbers are now functional
      • Search box now autoscrolls with the text
    • Fixed in v0.92b
      • Error 'comctl32.dll' is taken care of -- Thanks replicant for discovering this bug
    • Fixed in v0.93b
      • Removed unnecessary variables
      • Fixed minor interface bugs
      • Enhanced Song List manipulation
      • Further tested the plugin
    • Fixed in v0.94b
      • When embedding in its own skin in RR, the OSK would collapse on itself on initial call. Issue fixed.
    • Fixed in v0.95b
      • Switched to the current JTFP Build 49 (from Build 20!) -- reason above
      • Changed back to the standard, unskinnable base Jump plugin from Winamp -- arguably faster on load
    • Fixed in v0.98b
      • Improved search time by 70+ percent!
      • Better handling of the PgUp / PgDn / Up / Dn OSK commands
      • More accurate OSK searches (due to efficiency impovements)
      • Takes significantly less CPU resources
      • Cancel button works every time
    • Fixed in v0.98.5b
      • v0.98b would crash after pressing 'Enter' when searching via the keyboard
      • Unnecessary functions removed
      • Unnecessary variables removed
      • Unnecessary delay timers removed
      • Priority by button size is set (largest button = highest priority)
    • Fixed in v0.99b
      • Advanced Skinning Ability Added!
      • Better code handling. Removed ~200 lines
      • Discarded 50+ Variables. Allegedly less memory usage (knowledgeable testers, please verify)
      • QueueList PageDown scrolling fixed
      • Unnecessary delay timers removed -- only one 100ms delay left
    In case you've missed the download link above
    Download Plugin Here!
    In case you still need the old version (v0.98.5b):
    Old Version!
    Have fun with it, and Thanks for your time!
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Works fine on my desktop. Looking forward to a carPC version.
    Good app, keep us posted on your progress!
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    FLAC edrex's Avatar
    Dec 2004
    Ah, I didn't have RR running. Still, now it works like it should.
    You should add the "Move After Current" option.
    Question: After I have manipulated my playlist how I like it, what then? Hit the red X to close your program, or is there another way to get back to RR? Once you change the list it does not seem to update the playlist in RR. I'm probably missing something though.
    EDIT: ^^Nevermind, played with it more and found that instead of rearranging songs on the playlist, it just skips around through them. Pretty slick!
    FLAC edrex's Avatar
    Dec 2004
    Tested the new one. Check your PM.
    Apr 2005
    Quote Originally Posted by edrex
    Problem fixed, new Alpha released.
    Saturated_Fat's Avatar
    Dec 2005
    Rockville, MD
    Lookin good, definitly remembered in my book!
    Curious to how you'll integrate it into RR, subscribed.
    Shotgun! - An Advanced CarPC Software Solution!
    Apr 2005
    Quote Originally Posted by Saturated_Fat
    Thanks for the subscription!
    Please do not integrate the current version into RR because it's not CarPC "safe," yet.
    I need to work on more GUI (mainly the OSK) before you could use it in a car environment.
    @Everyone:
    Before I continue development, is anyone experiencing problems with the current Alpha?
    Apr 2005
    v0.8b Released
    OSK Added!
    Up Next:
    Big List Arrows (for scrolling up and down)
    Primitive Skinning Capabilities
    Apr 2005
    v0.85b Released
    List Arrows Added!
    Up Next:
    I need feedback!
    If there's anything you'd like to say about this program,
    If you have a feature request, or something is buggy,
    THIS IS THE TIME TO TELL ME...
    Thanks.
    P.S.
    I realize that some of you may not want to try this program because of the pre-installation procedures.
    I assure you: they are minor, and it won't take you more than a minute to be up and running.
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    Looks awesome DJ, will try it out tonight.
  1. File Sync Beta Testers Required
    By ric355 in forum EZSync
    Last Post: 07-01-2005, 02:20 PM
  2. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
  3. jump to winamp plugin?
    By metlok in forum Software & Software Development
    Last Post: 05-12-2002, 11:24 PM
