Still wondering. Is there a solution to display information like oil temp/pressure, voltage, etc.. what you would normally do with gauges on RR? My car is non OBD (1991 Toyota MR2) and the Touchscreen is now where I had 3 gauges.
Printable View
I have an obd2 interface on my carpc but it doesn't display that much. Speed, Rpm, air and fuel pressures, coolant and air temps, O2 sensor voltages, trouble codes and Rich/Lean ratios. No way to get MPG from that though the car does have an mpg readout. Still interested in the plug-in though
you could estimate instantaneous mpg based on rpm, injector pulse width, injector size, number of cylinders and speed.
I've begun development on an RR OBD plugin in this thread:
http://www.mp3car.com/vbulletin/rr-p...plugin-rr.html
It functions fairly well at the moment and calculates MPG for MAF and non-MAF vehicles.
Take a look.
i will have to try if my innovate ot-1 would work
just don't know if the output is the same kind
