Results 1 to 9 of 9
Thread: RoadRunner SDK Problem - .Net 2005
    Aug 2006
    Hi all,
    I was going to have a play around with the roadrunner sdk but the .net sample errors on upgrade, I have managed to sort out all but one of them.
    I'm getting:
    "'AddressOf' expression cannot be converted to 'Integer' because 'Integer' is not a delegate type" - Line 77
    I think I have to add 'Private Declare Function SetWindowLong'........ ?
    Bit stuck here as I haven't fully got my head around all this yet.
    Cheers
    Aug 2006
    Los Angeles (Woodland Hills), CA
    You don't have AddressOf operator in VB.Net anymore... PLus it is a bad idea to try and convert old vb6 code to .net. It'll just completely mess up everything.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you want to SEND commands to RR, you can just use the EXEC.EXE provided with RR. To receive commands, you'd have to implement the Window Procedure. Still if you ask nicely, I can make you a simple COM object to send/receive data to/from RR, that should be easy enough to use in .NET or anything else. (I honestly thought that the .NET example was in working condition -- apparently not, and I'm not the author)
    Ride Runner RR's Myspace
    Aug 2006
    Thanks Guino,
    All I need to be able to do is find out if RR is currently playing anything (so that I know weather to pause, and if to resume when finished)
    I understand that I can easily pause using EXEC.exe but if there isn't a way to determine if nothing was playing in the first place my plugin will then start something when it exits.
    Hope that makes sense!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you use: "EXEC.exe PAUSE" it will never play if it was already paused, as "EXEC.exe RESUME" will never pause if it was already playing. I'll build the COM control regardless.
    Aug 2006
    Aha! I was thinking exec.exe PLAY to start music again - hence I thought I would play even if not playing before!
    Thanks for the pointer
    Aug 2006
    What about to add a DDE server to RR? It would be very easy (and resourceless) to pass commands to RR, without using an external exe or embendding a com object into your project. Just an idea.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    DDE is too buggy for my taste.. it doesn't work in lots of machines (for no apparent reason), then it gets messages doubled and all sorts of little issues like that.. but I guess it could be added.. The COM object I'm thinking of, would be just a DLL file created with "CreateObject".. very simple and accessible from anything without the trouble of having to insert it into a form or anything like that. However, the API method (as in the SDK example) still is the most reliable and most resource-efficient method.
    Aug 2006
    Thanks, i will have a look into it. Actually i would like MORE the DLL solution, but that's why i'm a programmer, i just guessed a DDE solution would be more easly for who is looking for a fast link without invest to much time into library declarations or so..
    Well atm i don't have so much time outside programming "for my job", and im glad to you for your time investing into this.
    Cheers.
  1. Developing Touchscreen SDK -- need feedback!
    By kevlar in forum Software & Software Development
    Last Post: 07-14-2005, 05:55 PM
  2. SDK command request
    By tolisn in forum FreeDrive
    Last Post: 04-17-2005, 12:43 PM
  3. roadrunner problem
    By i3igmind in forum RR Bug Tracker
    Last Post: 03-19-2005, 04:03 PM
  4. Problem with Rikaline and MS S&T 2005
    By iamConceyted in forum GPS
    Last Post: 02-24-2005, 10:49 AM
  5. Replies: 4
    Last Post: 01-01-2005, 04:19 PM
