Results 11 to 20 of 24
Thread: Keyboard language indicator extension plugin
  1. #11
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Thank you for all your time. I really appreciate it. I can code just enough to use what you have just provided. Thank you again
    The road is long but we are getting there.
  2. #12
    Nov 2004
    France
    Go D6 Name thread and see last post of yesterday about VOSK : virtual Keyboard that use Windows'one with transparency so his configuration is the same your real keybord.
  3. #13
    Dec 2003
    Greece
    I tried out the code and it works great. I’m having a problem when I compile the code and make an .exe file. When I run the code from within VB everything goes OK but when I run the compiled file, the code does not do what it is supposed to do.
    In brief, the program checks for the keyboard language. If it is Greek, it will copy a file from a source directory to a destination directory. If the keyboard language is not Greek it will erase the file in the destination directory. When the code is executed from within VB it does the above. When it is executed from the compiled file it does not. What am I doing wrong ?
    Attached Files Attached Files
  4. #14
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try c:\ instead of c:/ on the paths.. other than that, if it still doesn't work, remove exit_prog from form load and see if it works (should show a window then).
    Ride Runner RR's Myspace
  5. #15
    Dec 2003
    Greece
    I tried both of your suggestion Guino both still nothing
    When I run the .exe I can see the keyboard language change to English, even if it was set to Greek. Why is it doing that? The program runs fine in VB. It does not change the keyboard language and does what it is suppose to do.
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ohh... so it's a different issue..
    Windows launches applications on a "default" language, so that's likely the reason it's "switching to english" (truly your app is just starting in english). To prevent that from happening, you'd have to prevent from running the application and add the code into the application currently running.
    I'm unsure what you're trying to do, but if you tell me, maybe I can help you with it.
  7. #17
    Variable Bitrate Evolution VIII's Avatar
    Dec 2005
    Miami-Florida-USA
    Quote Originally Posted by tolisn View Post
    No need for a form. try this
  8. #18
    Dec 2003
    Greece
    Quote Originally Posted by guino View Post
    @Guino. I'm trying to use the RR command EXISTS so I can set the state of an indicator depending on the language of the keyboard.
    The code that (even the one in the last post) EVO posted works Great when called from within VB. If you run the .exe then it changes the language of the keyboard to English and due to this fact does not copy the file to the directory ( it's supposed to copy a file to a directory when the keyboard language is Greek) so I can check it with the EXIST command. Any ideas?
    @EVO. Your last code does the same. It's perfect when executed from within VB but does not work when excuted through the compiled .exe (because the keyboard language is always changed to English.
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try this extension plugin.. look at the TXT for the new codes.
    I'm hoping that executing the API call from the same process as RR's it will display the status as it is set in RR.
    Let me know how that works,
    Guino.
  10. #20
    Dec 2003
    Greece
    Wizard Guino to the rescue. Thanks a million Guino. It works GREAT.
    Thank you all for your support.
  1. Replies: 44
    Last Post: 05-22-2009, 02:51 PM
  2. RR 03-12-05 .. Keyboard Support ...
    By guino in forum Road Runner
    Last Post: 03-15-2005, 02:48 AM
  3. Replies: 10
    Last Post: 02-13-2005, 08:28 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Keyboard Plugin for Winamp
    By Kevin in forum Software & Software Development
    Last Post: 08-21-2000, 10:43 AM
