Page 3 of 18 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 178
Thread: TrafficDetails- Rss Feed Plugin :)
  1. #21
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    I can't get any plugin to load what are you guys putting in the command lines for button.
    I am doing 'LOAD;traffic.skin" just and example
  2. #22
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    in the freedom skin example there is a button code txt that has the button code to launch the trafficdetails.skin. Without reading the sample skin you wouldnt be able to get anywhere
    Basically your skin file MUST include 10 labels. the code for these labels is !Feed1 through !Feed10. These labels must be long enough length wise to fit whatever the feed is (so pretty damn long) else nothing will show. If you have at least that in a trafficdetails.skin you should the data showing.
    but for future reference the button code is:
    B,0,0,0,0,"LOAD;TRAFFICDETAILS.SKIN||runq;C:\Progr am Files\Road Runner\TrafficDetails\trdetails.exe||SETLABEL;!las t;Last Updated:",
    no space in !last
    the zeros of course are the positining of wherever you want the button to be
    Live mp3Car Facebook Chat
  3. #23
    Jun 2006
    Houston, TX
    Quote Originally Posted by Sonicxtacy02 View Post
    no space in !last
    I am using your skin sample and i still dont get anything. its dead man I can't get any feeds.
  4. #24
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by tn6478 View Post
    ok you've added everything in my skin sample to your skin folder? added trafficdetails folder to C:\program files\Road Runner? You've put a button somewhere in your skin with the code i just put up(same code from BUTTON LAUNCH CODE.txt?
    you have to be more descriptive than "dont get anything" Does the skin load? If the skin doesnt load you dont have the button code right.
    copy and paste your rss site from trafficdetails.ini
  5. #25
    Jun 2006
    Houston, TX
    The skin loads the script run no feeds at all. Everything is where it should be
    Trafficdetails in the root of RR which is C:\program files\roadrunner. the trafficdetails.skin in my skin and i am loading it up but no feeds.
    I was using "LOAD;trafficdetails.skin;C:\Program Files\Roadrunner\TrafficDetails\trdetails.exe"
    I am currently using the rss detail from your skin to test too.
  6. #26
    Woodbridge, VA
    Blog Entries
    55
    you're using
    Code:
     B,0,0,0,0,"LOAD;TRAFFICDETAILS.SKIN||runq;C:\Progr am Files\Road Runner\TrafficDetails\trdetails.exe||SETLABEL;!last;Last Updated:",
    ???? as the button to LOAD the trafficdetails skin (not on the skin itself, but to load it)???If so, then load the skin and manually start trdetails.exe Do the feeds show up then?
  7. #27
    Jun 2006
    Houston, TX
    you're using
    Code:
    the exe run but then no feeds. Look like it trying to grab something down but i just get a blank page. is there something i need in the ExecTBL.ini.
    but actually i am using this to run the sking
    "LOAD;trafficdetails.skin;trdetails;C:\Program Files\Road Runner\TrafficDetails\trdetails.exe;trdetails"
    Man any idea what is going on this is driving me nutz i been on this for hours.
  8. #28
    Woodbridge, VA
    Blog Entries
    55
    k... if the program is working error free and the skin is loading.... it has to be the link u supplied to trafficdetails.ini. So... again... post the link! lol
  9. #29
    Jun 2006
    Same here -
    I am working around the odd piece of the skin not loading, and embedded the syntax on a button to load a skin page for me that would load - and putting the labels there.
    I am still coming up with null labels...
    I am continuing to test!
  10. #30
    Jun 2006
    I still remain stupidly confused on how after you run the file - then load the labels which RR will display? But honestly I would not know so would need to be edikated
  1. RSS Feed
    By Gobby in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-12-2008, 03:06 PM
  2. Feed (rss) news to voice reader
    By f1vlad in forum General MP3Car Discussion
    Last Post: 08-07-2006, 01:06 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Found Something Interesting On MY Dig RSS Feed
    By cavramair in forum General Hardware Discussion
    Last Post: 03-11-2005, 08:03 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
