Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 118
Thread: Embbeded Mp3 Art Plugin
  1. #101
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    And do keep an eye out for the next RRMeda update, not time frame yet but working on the code little here...little there..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #102
    Low Bitrate titanicmusic14's Avatar
    Jan 2008
    Pennsylvania
    mp3art
    Quote Originally Posted by treetop777 View Post
    If you are willing to use DFX3 'cause u can browse without scanning your music, DFX4 gives you that same exact functionality with the added benefit that it's proven to display embedde art with no problems.
    Install DFX4 and tell it you DON'T want to use RRmedia by pressing and holding the browse button then selec "standard"
    That made the browser work. now all we have to do is get the album art working.
    auto it error
    line-1
    error" subscript used with non-array variable
  3. #103
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Run RR as administrator
  4. #104
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    dll needs updated?
    dll wont register on Win 7, tried on 2 dirrerent systems
    "The module 'mp3art.dll' was loaded but the call to DllRegisterServer failed with error code 0x80004005."
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  5. #105
    Mar 2004
    Greenacres, WA
    dll ok, problem solved
    my bad, have to run command prompt as administrator to allow dll to be registered
  6. #106
    Mar 2008
    screen!
    RUSSIA - WINER!!!
  7. #107
    Jan 2010
    Quote Originally Posted by guino View Post
    I'd suggest you try the following before going overboard with it... since I've never used/heard of mediamonkey.. I would like you to download ID3 Tag-IT and use that to put a picture (album art) in one of your songs. Then go in RR and see if it shows for that song.. if so, then the problem is the software you're using, if not, then send me a private message and we'll do some tests together..
    Hi Guino,
    I'm also using mediamonkey to embed art. It's incredibly easy to search, and if it can't find it, I can search myself on google image or whatnot, and click drag the jpeg directly into mediamonkey, which adds it to the MP3. It also recognizes mp3's with identical albums and embeds the art into each mp3.
    Having said that, that's what I did, and 1 out of 3 mp3s shows corrupted in both RR and windows explorer thumbnail icons. on my main system the mp3s look fine on all apps I load it with.
    See the screenshot below:
  8. #108
    Jan 2010
    Found a workaround to my own problem. No matter what I tried I couldn't get a clean jpg to display on those select mp3's in the screenshot above.
    In frustration i removed all art from the mp3 completely, then went back in and added the art. Magically it worked!! I tried it on the other ones that showed corrupted images and they were all working.
    So if you're using Mediamonkey to embed art and it isn't showing like it's supposed to .. try removing the art, saving, then readding it again. I don't know why this is necessary, as it reads fine in MM and Winamp, but neither WMP nor the windows explorer thumbnail view would read them.
    I'm keeping MM open on one side, and windows explorer open on the other side, as I tag them i refresh the explorer screen to verify that windows/WMP can read it, which should match what RR can read (I am using WMP in RR to play the audio.)
  9. #109
    Low Bitrate Belo's Avatar
    Jan 2010
    Buffalo, NY
    i can't seem to get regsrv32 to work. I dl'd the file and placed in riderunner folder
    then ran
    regsvr32 C:\Program Files\RideRunner\mp3art.dll and it keeps giving me an error. Any idea?
    09 Pontiac G8GT [decently modded]
    former carputer owner, given up for iphone
  10. #110
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by Belo View Post
    then ran
    What OS are you running? 64-bit?
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  1. AVS hides behind Album Art
    By dougmorgan99 in forum Road Runner
    Last Post: 01-18-2006, 10:56 AM
  2. MP3 goes 5.1
    By camsgs3 in forum Software & Software Development
    Last Post: 01-14-2005, 04:43 PM
  3. Album Art / Movie Art
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 04:38 PM
  4. In dash car MP3 CD Costs
    By mp3designer in forum Classified Archive
    Last Post: 02-06-2001, 03:23 PM
  5. Car MP3 Costs???
    By mp3designer in forum General MP3Car Discussion
    Last Post: 01-24-2001, 10:45 PM
