Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Email indicator Plugin
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Can someone point me in the right direction for how to make an RR skin show an indicator for the # of emails in a pop account? Is this possible?
    EDIT:
    Guino> See post #7 for plugin by festy.
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by Enforcer View Post
    You'll need a plugin that can get the info and the create a custom label.
    Thanks - you know, since my daughter was born and I've been reading books to her, I finally get your blurb you have in your location.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    writing a plugin sounds like the solution, however, you'll have to write something to obtain the number of emails from whatever application or server you're using -- most likely different for each application/email server. Honestly seems a whole lot of work for something little.
    Ride Runner RR's Myspace
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Hark View Post
    The bit about the high rise I used to have swimming around in my head for years, it was only about two years ago I actually looked at the whole of the proper verse and added the second half.
    Feb 2005
    Atlanta, GA USA
    Thanks for the replies - I guess I'll just have to use a widget/gadget from konfabulator/yahoo, desktopx, etc. for getting the counts of unread pop mail.
    Since I deinstalled my car pc, I want to use my Xenarc as a secondary screen to my desktop, sort of a touchscreen mini control panel. My plan was to use Roadrunner for this, to display the time, date, weather, rss news, and I thought it'd be neat to have some email indicators, to know when I have new mail without openining up Outlook, etc. Perhaps I can crack open the code from some of the afore mentioned widgets to see how they do it, and write something that will return values to a label in RR. Perhaps it would be easier to have outlook running in the background, and have the label just represent # unread emails. The windows xp login screen has access to that info, perhaps it's easy to reuse?
    Low Bitrate festy's Avatar
    Jun 2006
    Sydney, OZ
    Here's a quick and dirty extension plugin for counting emails waiting on a pop3 server. Is this what you were after?
    It implements one label "emailcount_emails" and one indicator "emailcount_indicator" - the label is the number of emails on the server, the indicator is on when there's emails on the server, off when there's not.
    If there's a problem logging into the server (password wrong etc) the emailcount_emails label contains "ERR".
    There's a config file emailcount.ini that supplies pop3 server, port, username and password, and poll interval (in seconds).
    To use, stick the emailcount.dll somewhere on your system, and run "regsvr32 \path\to\emailcount.dll". Stick the emailcount.ini in the same directory as the dll, and change the server/username/password lines.
    In your menu.skin, add the line:
    X,emailcount
    then add the label/indicator to your skin somewhere.
    Attached Files Attached Files
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I was about to say that pop3 is probably one of the easiest methods to get that info from.. nice going festy -- I'll move this to the Plugin section.
    Feb 2005
    Atlanta, GA USA
    Thanks Festy - good on you mate.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    pretty cool
    beer replenishment fund
    mp3car live search
  1. Email I recieved from Creative about SPDIF
    By M5AM in forum Car Audio
    Last Post: 08-18-2005, 02:30 PM
  2. Car PC to read me my email and IM TEXT
    By TheSpecialist in forum Newbie
    Last Post: 01-30-2004, 07:38 PM
