Results 21 to 30 of 33
Thread: TimeExec Plugin
  1. #21
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Now with the new improved EVAL should be better to make multiple alarms
    EVAL;RESULT;strcomp("$VAR1$","$VAR2$")"
    2001 S10 ZR2
    Chucks Skin - to old
  2. #22
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I like this thing so much that I am adding 4 alarms, TV, hourly chime, hour meter and a count down timer.
    Will update pic when done
    2001 S10 ZR2
  3. #23
    Jun 2006
    Guino - all - timer plugin or misc....
    Guys -
    Not sure this plugin will work, or if some other may require too much CPU cycles but - here is what I hoping for.
    I enter into a skin page - timer runs on that skin page - at end of that timer it executes a valid RR command sequence.
    The most simplified way to understand this is with a VideoPlayer skin I am creating. When I get to the video player screen (using an External Player which Guino will be posting details on soon - ZoomPlayer) it will have all transit controls. Then after 60 seconds it will ultimately switch to it's flavor of fullscreen skin.
    So this would need to run upon entry to the VideoControls page - then countdown - then switch to VideoFull skin after seconds=x.
    Advice guys?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There are two commands, IDLE and TIMER, just place either IDL,60 or TMR,60 on the .skin files, and it will execute those commands which you can define in ExecTBL:
    "IDLE","COMMAND",video_player.skin
    "TIMER","COMMAND,video_player.skin
    Let me know if it doesn't work.
    Ride Runner RR's Myspace
  5. #25
    Jun 2006
    Guino - and once again I thank you sir.... You will see in the example I sent you how that would handle the "auto" transition from PlayerScreen to the FullScreen (or almost full) --- thanks so much sir...!!!
    I will try shortly.
    Quote Originally Posted by guino View Post
  6. #26
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    not sure why this isnt working for me
    08:00,BYVAR;TIMEBLOCK;NETTESTER<<DONOTHING
    nettester and donothing are defined correctly in the skin exectbl.ini. i used setvar;timeblock;0 in the STARTCOMMAND of rr.ini
    Live mp3Car Facebook Chat
  7. #27
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by Sonicxtacy02 View Post
    it should work
    test this
    08:00,NETTESTER
    2001 S10 ZR2
  8. #28
    Woodbridge, VA
    Blog Entries
    32
    hmmm i tried it on a different pc and it worked. How odd.
  9. #29
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yea Sonic, just some FYI, if you need to set any var's at the start of rr the more natural way "I think" is just add the var right to the rr.ini file.. and it will just automaticlly create and set the var.
    rr.ini
    timeblock=0
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #30
    Woodbridge, VA
    Blog Entries
    32
    ah that is good to know. Thanks for the tip!
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. Hello World plugin
    By paulpv in forum CF Plugins
    Last Post: 06-08-2006, 11:07 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
