Page 8 of 8 FirstFirst 12345678
Results 71 to 78 of 78
Thread: GPSGAS iguidance addon :)
  1. #71
    Mar 2007
    ...so the zip-code RR Label is your current zip-code based on your current GPS coordinates? (How does it get that data?)
    If thats the case, couldn't I just add a button to my GAS Prices page that copies that label into the zip code box? How come no one had done this on most of the skins I have tried or seen YouTube videos of?
    I need to know the lowest gas prices in whatever area I am currently in (without knowing the ZIP code of that area). Every YouTube video of GAS Prices in use shows the user manually entering the zip-code.
    Thanks.
  2. #72
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by newb77 View Post
    Thanks.
    the CURRENTZIP label is your current zip code. its determined by the zips.dat file. i coded rr to take your current lat and lon and find the closest zip based on that info. as to why thats not being utilized in the gas feature.. probably because noone has coded for it.. nothing more nothing less. the data is definitely there to be used though. it would probably take a vb guy 10 mins of time to code the use of the CURRENTZIP label into gas.. i just dont have the time between my skin and the movietimes plugin.
    Live mp3Car Facebook Chat
  3. #73
    Dec 2007
    Great work sonic!!! Finally got mine working after hours and tons of reading... and trying over and over thinking i might have done something wrong.... but, it was rather simple thing..... captions.....
  4. #74
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I modded this a bit to work with the enforcers new RRgas plug in and changed some of the methods it uses to find the windows.
    Pretty much the same now, waiting for sonic to give me the OK to release it!
    New Age Garmin - Skin for RR
  5. #75
    Woodbridge, VA
    Blog Entries
    53
    good to go.. release your version
  6. #76
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    I know this is 4 years old since the last post and really out of date but does anyone still have the gasnav.rar file that I can get?
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  7. #77
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    There you go.
    For RRGasNav, you will need a modified version of iGuidance to navigate by coordinates.
    It is an Autoit script.
    Attached Files Attached Files
  8. #78
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by SteveC View Post
    Yes, just downloaded a fresh copy and opened the .exe in reshacker - then went to 'Add a new resource' imported the 1092.res file. Then tree expanded the 1092 and saw the 1033 which I clicked on - the dialog opened and I could open and close but the compile script was greyed out.
    I am use Blue Devil skin by the way (cos it's awesome!)
    Quote Originally Posted by MGD View Post
    There you go.
    Thanks but still confused.
    I wasn't around or at least reading this thread when it first came out so I am trying to understand it.
    I am trying to see if I can get it to work with the latest version of Iguidace 4.2 (2011) using the same steps to get this one to work. It might not work but wont know till I can try it I thought in the original gasnav.rar there would of been instructions in there on how to create the 1092.res file, import the 1092.res file and maybe the 1092.res file itself in there ready to get imported into the exe file as I don't see any detailed instructions in this thread.
    I did find what I quoated above. (see above)
    I have the older Iguidance 4.0 and the newer version 4.2 (2011) I have the 4.0 working corectly.
    What it comes down to is the text I see in the in Resource hacker the 1092 text how do I create a new 1092.res file or export with all that text and import it into the new Iguidance exe?
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  3. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  4. Hacking Iguidance
    By Peoples in forum GPS
    Last Post: 08-28-2005, 07:40 PM
  5. Replies: 2
    Last Post: 08-19-2005, 12:15 AM
