Results 1 to 10 of 14
Thread: e36 BMW ac interface
    May 2005
    I"m thinking of building carpc for my 99 bmw,i got most of the stuff that is needed, but my only requaiment(for my self), is to have full control of ac. I was thinking of using something like this(http://www.apogeekits.com/usb_input_output_k8061.htm) for interface, but sw part would be a problem, what would be the easiest way to integrate this to RR? Here is a pic of accual ac module:
    Thanks, Russ
    May 2005
    could anyone point me in right dirrection on how to write driver/plugin for this, or how it would be done, TIA
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well there already is an RRPlugin for that kit or a similar one
    Velleman K8055 USB I/O Board Extension plugin
    however the main problem is going to be working out how to actually control the CC with the software and where exectly to connect to it.
    You will need to find out more about the way the CC works.
    Also I think most people that want to control their A/C will be those with manula controls.
    If you have any success keep us posted coz I also have the same CC.
    Variable Bitrate 307SW_NLD's Avatar
    Apr 2005
    The Netherlands
    Depends, how many input and outputs do you really need?
    There is a RR plugin for the K8055 board which has a 5 bit input, a 8 bit output and two analog inputs and outputs. See: Velleman K8055 USB I/O Board Extension plugin
    I don't think is would be hard to make that plugin available for the K8061 as well but I only have a K8055 to test....
    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
    Hardware: None at the moment
    Software: None at the moment
    See: Velleman K8055 Plugin for Road Runner
    Progress: [XXXXXXXXXX] 0 % DONE
    May 2005
    where would i find info on how to make plugin and other info like that, i tried FAQ, but didnt find anything
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by DakarM3 View Post
    Your main concern should be finding out more about the climate control module first, then when you have more information, others here will be able to help with the plugin etc.
    May 2005
    ok, i got some wiring diagrams comming
    May 2005
    May 2005
    if there is more info needed, or i got wrong stuff just let me know
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well, looking at the pin assignments you have a number of inputs and outputs, what you need to determine is whether they are digital I/O's (ie ON or OFF) or analogue (ie have a variable voltage).
    Also you need to find out what the voltage ranges of the variable ones are. (temperatures ones for example)
    Also finding out what the CC is doing with the information fromt the RPM input and vehicle speed siganl input and then outputting to the DME (RPM speed increase).
    The is a hell of a lot of different variables in this and it won't be a simple job.
  1. 2003 BMW M3 Custom Dash / Overhead Console
    By gork in forum Show off your project
    Last Post: 01-01-2008, 07:52 PM
  2. Bmw Car Interface
    By ctwizard in forum Software & Software Development
    Last Post: 09-11-2005, 07:56 PM
  3. lilliput 7" vga in bmw e36 coupe? HELP!!!
    By rockyfozz in forum Newbie
    Last Post: 08-05-2005, 06:42 PM
  4. XMdirect cable + Sony Unilink Interface. help!
    By d2.n in forum General Hardware Discussion
    Last Post: 03-17-2005, 03:36 PM
  5. FS: OBDII diagnostic interface
    By deskcom in forum Classified Archive
    Last Post: 12-09-2004, 11:24 PM
