Page 2 of 17 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 165
Thread: Interactive *Flash* Traffic Maps Plugin!
  1. #11
    xgc
    xgc is offline
    Aug 2006
    florida
    Hi Moahdib works great and thanks alot!
  2. #12
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Another way will be to use the local live SDK and have a local .HTML file that loads only the necessary info (so you don't have to use the browser) I start this project long time ago but never finished (has I already stated in sonics traffic plugin thread)
    Quote Originally Posted by thanatos106 View Post
    Ok I have to say that I'm pretty busy right now so I haven't been able to work on this but:
    There may be a way to pull the flash maps from traffic.com or maptuit (just the same as embeding pandora)
    or
    Have the info from traffic.com filter by windows live local (that is the way I do it but i was thinking on using the live SDK so the web doesn't have any of that garbage, just the info that you want)
    Live traffic/traffic cams
    Thanatos.
    TrafficDetails- Rss Feed Plugin :)
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  3. #13
    moahdib's Avatar
    Jul 2000
    Quote Originally Posted by pshadwick View Post
    Works great, can you make it parameterized so that I can pick the city?
    Thanks...Paul
    I know I can pick which city I want, but I will likely want to change the selection on the fly.
    ...Paul
    Yeah i think an autoit script should do the job, but don't look at me =) I'm sure someone else can easily figure out how.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  4. #14
    Nov 2004
    Ok for you guys that tryed in TS, how are you bringing the info of the accident/const. up? (last time I tryed the map in traffic.com site you have to hover on top to bring the deatil and that is impossible with a TS **at least with the TS software ver that I have**)
    Thanatos.
    Nissan Aux-in MOD
  5. #15
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    great job.. i can now stop tryin to put together my map program
    Live mp3Car Facebook Chat
  6. #16
    Nov 2004
    St Louis
    Great job! Now if I can only figure out how to change the traffic.ini using the trafficcity variable.
    EDIT: O.K. got it working on the fly based on the text traffic pages. I had to use RRCode to change the traffic.ini file and a batch file to delete traffic subdirectory files, but I found out you have to delete 4 files: basemap.swf, digital_segments.swf, map_init.xml, and map_update.xml. For some reason I also have to run the "traffic data updater.exe" twice before it shows up in the skin with the right data.
    One thing that gave me hell was it won't work unless the header [MyCity] is in the traffic.ini file.
  7. #17
    moahdib's Avatar
    Jul 2000
    Thanatos.
    I believe I have to make the "incidents" icons a little bigger for it to work on a TS. I never bothered to actually check incidents in the car.. I mostly just use it to see traffic flow. I'll also put some better looking zoom buttons there when I have some time.
    My TL CarPC ver2
  8. #18
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    fix the readme. The button to load the skin is wrong. you used a colon instead of a semi colon
    change LOAD: to LOAD;
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  9. #19
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by Ruffy View Post
    This and you can put $SKINPATH$ instead of C:\blah blah so that it works for everyone no matter where there skinpath actually is.
  10. #20
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Sonicxtacy02 View Post
    (I wonder where he got that idea from)
  1. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 08:26 PM
  2. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 05:20 PM
  3. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 09:09 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
