Page 3 of 17 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 165
Thread: Interactive *Flash* Traffic Maps Plugin!
  1. #21
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Enforcer View Post
    (I wonder where he got that idea from)
    yes yes i learn from my mistakes lol.
    Live mp3Car Facebook Chat
  2. #22
    Nov 2005
    Missouri
    I really like this...But... Traffic.com is missing some of the cities I frquently travel through.
    This msn link has several additional cities (such as Memphis)
    No doubt there are other links as well.
    So.. Would it be easy/possible to use this (or other) links also.
    http://autos.msn.com/everyday/Traffi...pd=1&metro=KCY
    Thanks...Paul
  3. #23
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Work great. Instead of having this traffic thing locate inside particular skin, you can try this.
    - Extract the "Traffic" folder inside RoadRunner folder just like weather folder (C:\Program Files\Road Runner\Traffic\). Do the same for the flash file (C:\Program Files\Road Runner\Traffic.swf).
    - Add this line to ExectTBL.ini file "TRAFFIC","LOAD;TrafficMaps.skin||RUN;C:\Progr am Files\Road Runner\Traffic\traffic data updater.exe" Do this only if you want to use "TRAFFIC" as a command, unless yoiu want to add that line to every skin you use.
    - In TrafficMaps.skin file simply add the flash movie
    Code:
    /, F, x, y, w, h, Movie name
    F01,140,70,655,340,"..\..\Traffic.swf"
    Okay, the called to Traffic.swf file is using "relative path" instead of direct path like this.
    C:\Program Files\Road Runner\Skins\My_Skin\TrafficMaps.skin
    Okay you ask, Why the hell do I have to go to all this trouble?
    Well, with this configuration, I only need to have 1 traffic folder and 1 traffic.swf file in the system instead of one set on every skin use.
    <wishfull thinking>
    If you could make the fash file to change color via ini file or release the fla, that would be great (although I have no clue on working with flash).
    </wishfull thinking>
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #24
    Nov 2004
    St Louis
    Quote Originally Posted by MatrixPC View Post
    Code:
    <wishfull thinking>
    That's a great find. I was so caught up trying to make it interactive , I forgot to look at keeping it clean, too. Could you add a quick explanation of this and how it can be applied to other add-ins/plug-ins to the Skin Tweaks Thread
  5. #25
    Apr 2005
    Queens, New York
    i get the flash to load up my state but it does not plot the traffic data? And reason why?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  6. #26
    Apr 2006
    Refresh
    So I put together this little code in AutoIt to change the location via a button in RR but the .swf won't update until I restart RR. Is there a way to force RR to release it and grab it again?
    Note: Code written after moving files as Matrix explained
    Code:
    Global $cmdlineraw
    $RR_Path = RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\RoadRunner\Install", "InstallFolder")
    iniwrite("traffic.ini","MyCity","City",$cmdlineraw);
    filedelete(""&$RR_Path&"\traffic\basemap.swf");
    filedelete(""&$RR_Path&"\traffic\digital_segments.swf");
    run("traffic data updater.exe");]
    A button in the skin sends: San-Francisco-Traffic etc. to the .exe
  7. #27
    Nov 2004
    St Louis
    Quote Originally Posted by 1Munkey View Post
    If you made the page discardable, you don't have to reload RR just the page. You also have to delete the other two files I mentioned earlier. Try adding the following to the button code : "
    ||main||LOAD;TrafficMaps.skin||RUN;C:\Progr am Files\Road Runner\Traffic\traffic data updater.exe"
    This will quickly jump from the traffic screen to the main menu and back and also run the updater the second time. Ugly, but Should work.
  8. #28
    moahdib's Avatar
    Jul 2000
    Alright guys, I updated the flash file and took care of some of the requests =) Check first post.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  9. #29
    moahdib's Avatar
    Jul 2000
    If you add the line /discardable to the skin it should update it after you exit the screen and go back.
    ** after some thought I think the problem might be because the exe did not finish downloading the updated swf and xml files. Try using RUNW instead of RUN.
    My TL CarPC ver2
  10. #30
    Nov 2004
    St Louis
    I just thought of another way. You should have a wait skin in your skins folder. You could jump to that instead of main and then back to traffic. That would look much more professional.
  1. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  2. XMLTraffic Plugin
    By 307SW_NLD in forum RR Plugins
    Last Post: 09-14-2006, 06:20 PM
  3. Traffic Plugin for Centrafuse?
    By justintime in forum CF Plugins
    Last Post: 09-09-2006, 10:09 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
