Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: SHOUTcast plugin
    Apr 2006
    SHOUTcast plugin
    What it does: It takes my SHOUTcast playlist and tells me which song is currently playing on each station. So not only can I see the title of the song that I am currently listening to but also the songs on the other stations in case I see something I'd like to hear instead.
    How it does it: I have an .ini file which lists the ip and port of each url in my playlist. The .exe takes this data and parses the ip as if it were winamp. It then strips out the metadata with the title in it.
    Future plans (in order of plan, I know some are easy and will be done soon):
    - removal of single quotes around song
    - ability to update .ini by reading playlist
    - ability to recognize and highlight the current playing song
    which will lead to....
    - ability to change "now playing" in all skins
    - ability to change playlist with songs instead of url's
    Nov 2004
    St Louis
    Sounds good, need more details to fully comprehend what you're doing and how.
    Apr 2006
    Updated first post. Hope that clarifies a bit.
    Nov 2004
    St Louis
    If your script interacts with winamp, you might want to try my modified RR compile for internet radio. This is an unofficial mod that has K8055 functionality removed and may conflict with some RR functions. It is based on the last official release (11-12-06) and allows RR to read Winamp ATF coding from internet streams. This only updates the current playing song whenever you reload the playlist, but it does pull the entire stream title into the playlist. See below:
    Sep 2006
    Lancaster PA
    Gizmo, your link has expired. I am very interested in this, as a way to pull down Live365 broadcasts.
    Could you repost, please?
    Jeff
    Nov 2004
    St Louis
    Quote Originally Posted by jswalls110 View Post
    Jeff
    O.K. I reloaded the Link. It should be good for another week, same disclaimers apply.
    Constant Bitrate techeros's Avatar
    Mississippi
    kinda cool I guess if you have good bandwidth in th car and all... maybe wifi? But cellphone...? 115kbps... buffering like crazy on a 128 stream for decent sound... am i missing something?
    03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
    Carputer Planning |---------*|
    Overall Implementation |---------*-|
    (Stereo complete)
    Computer installed and working
    Nov 2004
    St Louis
    Quote Originally Posted by techeros View Post
    I'm running 153kbps with compression, so 96k and below are best I can do until I hit a WiFi hotspot, then I can run up to 196k streams.
    Dec 2006
    I stream 128kbps just fine using Sprint's EVDO here in Boston
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    1munkey,
    Do you have a link where I can download it?
    I'd really like to use it
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
