Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: Next & Current Street Labels from iGuidance
  1. #11
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    First post updated.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #12
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well, I take it that all is well with this as no one has posted any probs...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  3. #13
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    works on two of my computers with intel chipsets/graphics doesnt work on my computer with an nvidia card in it. I believe there's something about the native resolutions of graphics cards that make this not work for some people. I had the same issue with my igAddon utility.
    Live mp3Car Facebook Chat
  4. #14
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What part doesn't work, all, letter learning...ect, as this really shouldn't be card dependant at all, once you teach the letter defs for your setup. On these ones that don't work, is the street font color not the same white number as the other as that is the only thing that I could really see affecting the scanning/learning. If so then I will have to change the hard coded color match to user set-able.
    I also fixed the config to resolve the prob w/ the bars
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #15
    Apr 2006
    Little Confused
    So I have this up and running and it works pretty well for how difficult of a task this is but I have a few issues.
    1) is there a way to make the "ocr is running" box go away or is that because it's still in beta?
    2) is it only reading the label when ig is visible? It seems to not be reading anything when I'm in a different scren
    3) is anyone else getting the label only showing up in the gps skin? I can get the label to show up in the same screen it is read from but can't get it to update anywhere else
  6. #16
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by 1Munkey View Post
    Try DL'ing again, you have an older version, as there is no more window saying that it is running
    Yes, as it only reads the name(s) when iG is showing
    Didn't check, as I would assume that once you set a label to a value it should be read as such when changing screens.
    Edit: Ok I did just check and did notice that it does not in fact update the labels. Will add a option to check if screen changed and update if so..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #17
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    First post updated..
    Now it will update the labels when it detects that you changed screens
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #18
    Apr 2006
    Thanks Blue, haven't had a chance to tryout the new version but 2 questions that hopefully aren't answered:
    1) Is there a way to get it to not move the mouse. When I am using my test PC it pulls the mouse under the name as it reads, kinda annoying to be stuck until it's done reading.
    2) Related to #1, I noticed that it is translating the next street as it is scanning it. Is there a way to get it to scan it all quickly and then translate it? Only reason being is that I am using the switch on GPS screen and the time it's on the GPS screen isn't long enough for the program to get through the entire name. I end up with "Almaden Ex" instead of "Almaden Exwpy" or if I'm extremely unlucky and it doesn't catch the name fast enough I end up with "Al"
  9. #19
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    BEFORE, any more questions, DOWNLOAD the update!!
    FYI...when trying out different software\apps it's always best to get and try the lastest ver before asking about features/problems, as they might just already be fixed.
    Now, as far as the second one is concerned, what options are you using as far as the igauto goes? Are you using the lastscreentime, ect. I could see where this woud be a problem, will check out and figure out best way to fix it.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #20
    Apr 2006
    Sorry for not trying the current version first but I knew it'd be 24 hours til I get back to my test computer and knew #1 shed light on #2 which I was almost positive was still an issue.
    Yes, I use lastscreenswitch and pauseonvoice and all that great stuff to automatically switch to the guidance screen when directions are given. This poses two problems. (1) When it switches to the guidance screen it is in guidance mode which means that your program can't read the next street until after the turn which leads to (2) once I make the turn that leaves me with a limited amount of time to grab the "next turn" before I switch out of guidance. Using a 5 second switch you'll never catch it. 10-20 second switch was catching some if not most of it. A 30 second switch was catching the entire label but a 30 second autoswitch feels like forever.
    Thanks for your hard work.
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Release new phoco integration preview
    By Robby BMW in forum Road Runner
    Last Post: 09-12-2009, 06:29 AM
  3. Blue Devil Skin RELEASED
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 01-05-2007, 08:54 PM
  4. Launching iGuidance under Media Engine
    By StationRocket in forum GPS
    Last Post: 11-29-2004, 01:56 PM
  5. Delorme Street Atlas Nav Audio question
    By whatever in forum GPS
    Last Post: 01-13-2004, 08:37 PM
