bump.................... still getting the same autoit error over here... and i relaly want to implement this into my new skin.
Anyone else having trouble regaining their embedded album art after using older versions of El's plugin?
Even after using the "Album Art Downloader" to embed the album art in my mp3s, I still get a blank screen on the tracks where I used the older versions of the plugin.
Anyone know what I need to do to fix those tracks?
I'm using v2.1.0 now and works like a charm.
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
im getting the same freakin error with the new code. im sure its not your script that is teh problem because it works just fine for everyone else AND i looked through it and it all makes sense and looks fine. i reinstalled autoIT on the computer, same prob.
and it says:
line -1:
the requested action with this object has failed
not sure where the error is coming from....... and yes i registered the appropriate things.
Riderunner / Genesis
Wifiman_NET:Version 1.0.0
the error you are seeing is related with the dll, there are some different dll versions in this cddbcontrol.dll one is from cddb(the one that give problems with the embeded art), and after that AOL took over,so if you dont have the right version will give you the infamous error, but what i dont get is why, i'm including the right dll(AOL). heres the properties of the one i have and is included in the package.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
yea i googled this for a while earlier today and discovered the multiple versions of CDDB out there. i can assure you this is what i have done:
1) downloaded the package from the first post in this thread
2) put the tags folder in RR path
3) registered cddbcontrol.dll (tried with your register.bat and with a simple 'regsvr32 cddbcontrol.dll' command)
4) used the appropriate tag_editor.skin and made my own. also added the other *.skin files and pictures. ive been skinning awhile, i know how that part works...
5) click on a button to change the info, brings up the OSK, i type in my new info
then ERROR. this really shouldnt be that complex. i can confirm right now tho that this is an autoit error. thats what the error is coming from. this is all on my laptop, ill try the carputer later...
ok long time no update. ive got it working now, i have no idea what i did to fix it, but now it works.
New Problem:
-Sometimes it edits the wrong file. If i click on a song in a playlist, and then go edit it (while its playing), it does not edit that file. It will, however, edit the previous song, or at least the most recent song that was played without being selected from a playlist (i.e. clikcing next or previous to change the song). any ideas?
EDIT: it sometimes does this. sometimes not. whatever. just decided to let people know that i got it working (somehow.)
