Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 142
Thread: Tag EditorEx + Rate/Lyrics/Art/Music Search
  1. #61
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by guino View Post
    what are we trying to do now ?
    EL CAMINO has written a real handy script to edit MP3 ID3 tag info using RR's OSK.
    However, when clicking on the tag to edit, it opens up the OSK w/ a blank field. It'd be real nice to pass on the label/tag data to the OSK textbox so that you don't have to re-type the whole thing if you are just editting a letter or two.
    Not a huge deal, but more a convinience thing.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #62
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Pass a value (label) into the OSK when called via OSK to CMD.
    Ideally the contents of the variable to which the output is going should be displayed in the OSK if it already has a value.
    Sorry if that don't make sense as it's 3am here.
    ie from skincommands
    "OSKTOCMD;[HL]MYVAR[/HL];RUNQ;$MYVAR$"
    highlighted variable contents should be passed to the OSK
  3. #63
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Quote Originally Posted by Sal R. View Post
    OSK contents still empty.
    please go over the install again, the commands are different now, seems that treetop777 have it working. i been using and testing for a couple of days with no issues.
    @guino
    i do this purely in autoit, but would be nice to do it with RR's code, like the web plugin does
    when the button to enter a new url is hit the osk shows "http://www." automatically.something like
    Code:
    "OSKTOVAR;TAGS;STARTING TEXT"
    or even better, in all OSKTO and NUMOSKTO commands. this way can be used with any call. T
  4. #64
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Would you have any idea why my embedded album art are not displaying now? I haven't done much troubleshooting but it started when i installed the plugin. I use X,mp3art to display most of the album art.
  5. #65
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-Check if it works again by removing this plugin
    2-Change the order of the X, lines -- this does make a difference if there's a bug in one of the plugins.
    @EL_CAMINO: I've added a OSKTEXT command to set the text of the OSK/NUMOSK for next release.
    Ride Runner RR's Myspace
  6. #66
    EL CAMINO's Avatar
    Jul 2005
    !!!thank you!!!! guino.
    @treetop777
    seems to be the case, cut be something wrong in the mp3art plug in. winamp still shows the albumart, after the changes, and Road Runner doesn't do it after the changes. once again "Guino??"
  7. #67
    guino's Avatar
    Nov 2004
    Toronto, Canada
    did you do anything in your plugin to provide labels to RR ?? the bug could be in there and that could interfere with other running plugins.
  8. #68
    EL CAMINO's Avatar
    Jul 2005
    yes, just one, and is just a regular custom label, which is.
    Code:
    "!TAGS_COMMENTS"
    most of the code is for error trapping, and info reading. i you want i can send you the code, is simple as hell. child's play for you.
  9. #69
    guino's Avatar
    Nov 2004
    Toronto, Canada
    pm me the code for your Label procedure in the plugin -- it is an extension plugin right ? I'll take a look at it.
  10. #70
    EL CAMINO's Avatar
    Jul 2005
    well, as guino release a new updated RR version, the new command to preset the osk text. well be used to load the tag info if any, works a lot faster and looks cleaner, about the mp3Art plugin, seems to have some issues reading the Album art after editing tags. guino will take a quick look at this problem for me.
    thank you guino.
    EDIT:
    i tested the latest version with more than 20 mp3's and the album art is been untouched, still shows in RR mp3Art plugin.
  1. Playlist search bug
    By kobaz in forum RR Bug Tracker
    Last Post: 07-29-2007, 07:41 PM
  2. Search Engine Problem?
    By lkstaack in forum Mp3car Forum Suggestions/Comments
    Last Post: 05-29-2007, 10:18 PM
  3. Replies: 52
    Last Post: 07-03-2005, 08:00 AM
  4. FAQ: Why do people keep telling me to SEARCH?
    By tj!2k4 in forum The FAQ Emporium
    Last Post: 06-28-2005, 02:06 PM
  5. Help - A plug in that uses an mp3s ID3 tag to search for a song???
    By zzsprade in forum Software & Software Development
    Last Post: 02-18-2002, 12:33 AM
