Page 10 of 22 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 217
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #91
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I hate to do this but stick MSCOMCTL.OCX in the search box at the top and you will have plenty of solutions.
  2. #92
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    I just received the kit to beta test and I can not get the plugin to show any data. I know it is working because I have it working in Centrafuse fine. Does the plugin need to be updated or maybe it is something I am missing. I am using the default skin (Carwings) and I added it to the menu and registered the .dll and it launches fine just does not show data. Using Vista 32-bit and latest Riderunner.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  3. #93
  4. #94
    May 2005
    Lawrenceville GA
    Quote Originally Posted by Enforcer View Post
    Have you run the config program?
    Yes and both work fine. Both TPMS Doctor and RRTMS config.exe
  5. #95
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    When you press the TMS button in the main menu (you must to add it), the TPMS skin appears?
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  6. #96
    May 2005
    Lawrenceville GA
    Quote Originally Posted by Robby BMW View Post
    Yes it does.
  7. #97
    Aug 2005
    Italy
    Well, it seems that the plugin is correctly loaded.Can you post in attachment your TMS.SKIN file?
    It should be useful to understand what could be the problem.
  8. #98
    May 2005
    Lawrenceville GA
    For testing I ma using the supplied skin. No changes at all. I will post a screen shot later.
  9. #99
    Aug 2005
    Italy
    Ok, also a screen shot could be usefull.
  10. #100
    May 2005
    Lawrenceville GA
    Well it must have been a computer specific problem. When I installed everything in the truck RR worked fine and read the info no problem. I will be posting a review in the review section soon. Sorry to bother you. Good job! The plugin works great.
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 12-25-2011, 04:15 PM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
