Re audio,
Are you sure your speakers are working, and you have not got TPMS set to mute.
Also, have you set the messages, and they are not all blank?
Since you have no battery status also, I might suggest you uninstall and reinstall the software.
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
Re audio,
Hi Thanks
Regarding the Batt Status.... It Shows EMPTY always....
And
Audio yes the speakers are working and TPMS is not Mute
BUt i guess am not able to Set the messages properly....
Could you be kind enough to show me how to put in the messages for warnings and the code to display batt staus....
( or may be you can post in your copy of TMS.SKIN so i can read that and work from there )
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
just wondered, how do i most easy keep settings for 2 set of tires? (winter / summer sets)
are the ID of each sensor stored in the ini? in that case i can simply write a batch to change them around
or could it be possible that the next version will support 2 set of tires and just a winter summer toggle buttom?
When you rotate your tires then you just tell the program where the sensors are. If you change tires completely you have to goto the complete setup.
i know i can relearn when i change to another set of tires
but i was looking for an more easy way... where are the sensor id's stored? in the usb board?
I am sure they are stored on the PIC.
well.. could be cool to have a quick way to change between 2 set of tires... but i will do with relearn until then
of course... why did i not think that before... thanks for think better than my brain :-)![]()
