Page 15 of 27 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 266
Like Tree2Likes
Thread: RRTMS - RoadRunner tire monitoring system extension plugin
  1. #141
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    I like to know is mp3car shop's TPMS kit compatible with this plugin? If it is, does anyone try it and is't good?
  2. #142
  3. #143
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Pressure settings in ini file
    So, here is my delemma. I am trying to adjust the pressure settings for the RRTMS from within Road Runner. I wrote a script to read from the RRTMS.ini file to get the values and show them as labels in my skin. Everything is fine with that but here is the real problem. As you can see in the screenshot below, the values are not as set with the RRTMS Config program. If I run the program and set my values for the pressure in PSI to 20 for the low warning and 45 for the high warning and save the values, the ini files has different settings. 20psi will give me a value of 81 and for 45psi a value of 164. Does anyone know the formula to convert this back to a psi value as set by the config tool? Or maybe can be modifyed to store the settings in psi. Any help would be great.
  4. #144
  5. #145
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    The values in the ini file don't change when you change from psi to bar or kpa. That tells me there is a formula in his config tool to display right data.
  6. #146
  7. #147
    Nov 2009
    I have a question - sorry if this has been answered and I over looked it. I have an 08 tacoma X-runner that has built in tire pressure monitoring system. Is there a way for me to use this software and somehow get just a receiver that will read the current signal my sensors are sending?
  8. #148
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Quote Originally Posted by
    [B
    Added skin commands:[/B]
    COMANDS/BUTONS:
    “TMS” – Go to the main screen of the plugin
    “TMS_SILENT” – Silent mode. If active, the plugin will not show any warning
    INDICATORS:
    “TMS_SILENT” – Indicates that the silent mode is active.
    "TMS_ALERT_FL" - Indicates that in the front left tire there is an irregularities.
    How do i Know if the SILENT MODE is active.....
    can some 1 pls help me here
    Guys
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  9. #149
    Dec 2003
    Quote Originally Posted by vicky_obee View Post
    Guys
    BUMP !!!!
    Guess no 1 is interested in helping me out with this little query / help...
    Any way Guys
    have a nice day !!!!
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
  10. #150
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    BUMP !!!!
    Any way Guys
    Patience padwan, email notification is currently off, so no one in this thread will have go notification of your post, the only way is if they just happen to visit so answers will take longer.
    Any way to answer your question, you will need to put an indicator “TMS_SILENT” in your skin to indicate that it is running in silent mode.
  1. Velleman K8055 USB I/O Board Extension plugin
    By 307SW_NLD in forum RR Released Plugins
    Last Post: 02-24-2013, 07:59 AM
  2. Use serial port with extension plugin???
    By guillemasco in forum RR Plugins
    Last Post: 12-04-2006, 07:26 PM
  3. Extension plugin problems
    By festy in forum Road Runner
    Last Post: 06-23-2006, 07:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. Extension Plugin help ....
    By Gobby in forum Road Runner
    Last Post: 06-09-2006, 11:27 AM
